Author Topic: Fusebox FAQ  (Read 28310 times)
Offline mattkh
Re: Fusebox FAQ
« Reply #20 on: 04 August 2008, 20:21 »
Rubjonny
Which diagram  do I look at for a 1.8 16v 1991 kr  rado. Cheers.
Re: Fusebox FAQ
« Reply #21 on: 04 August 2008, 23:50 »
rubjonny, i love you, you just saved me alot of cash! ALOT of cash! Your my new favorate person! legend!
Salreet chap, glad it was of some help! You got the same wheels as me  :cool:
Rubjonny
Yours will be a mixture of post-90 MK2 & Corrado VR6!
Offline Roverdose
  • So long and thanks for all the fish!
Re: Fusebox FAQ
« Reply #22 on: 05 August 2008, 13:42 »
wanna sell em?
Re: Fusebox FAQ
« Reply #23 on: 05 August 2008, 13:44 »
would you? ;)
Re: Fusebox FAQ
« Reply #24 on: 27 November 2008, 10:06 »
Golf MK3, CE2 (for rear picture, see page 4):
A1
1 - yel/wht - left headlight pin 2 (dipped beam)
2 - blk/wht - front left indicator, alarm system control module pin 1, dash plug pin 22 (left indicator light)
4 - gry/blk - front left indicator & parking lights
5 - red - rad fan thermal switch pin 3
6 - wht/blk - left headlight pin 1 (main beam)
7 - blk/yel - horn(s) pin 2
8 - brn/blk - horn(s) pin 1
A2
2 - front right indicator & parking lights
3 - yel - right headlight pin 2 (dipped beam)
4 - blk/grn - front right indicator, alarm system control module pin 2, dash plug pin 24 (right indicator light)
7 - wht - right headlight pin 1 (main beam)
8 - gry/yel - rear fog lights
C
1 - blu/brn - brake fluid warning switch pin 1
2 - grn/red - washer motor pin 1
7 - brn/blu - washer motor pin 2
8 - blu/red - coolant level sensor pin 2
D
3 - blk/red - glovebox light pin 2
8 - blk - ignition coil, ECU pin 38, vehicle speed sensor pin 1, Junction connector TV4, airbag control unit pin 12
9 - blk/wht - Junction connector TV5
11 - blk/blu - Junction connector TV5
12- gry/blu - Junction connector TV8
E
2 - blk - Junction connector TV4
3 - blk/red - brake light switch pin 1
4 - red/yel - brake light switch pin 2
F
1 - red - alarm control unit pin 5, ECU pin 7, park/neutral position switch, starter motor pin 50
3 - blu - alternator pin D+
4 - brn - vehicle speed sensor pin 3
6 - blk/red - reverse light switch pin 2
- blk - Park/Neutal position relay pin 5
7 - blk blue - reverse light switch pin 1
G1
2 - brn/wht - outside air temp sensor
3 - yel/blu - ECU pin 6
4 - blk - ECU pin 38, gearbox speed sensor, ignition coil pin 3
5 - brn/wht - earthed to engine block
6 - brn - heated washer jets
- brn/red ECU pin 12 (1.8L)
7 - blk/brn - ECU pin 9
8 - red/yel - lambda probe pin 2
9 - yel/blk - ECU pin 5
10- red/blu - ECU pin 23, cam position sensor pin 3, evap canister purge valve, maf sensor pin 3, lambda probe pin 6, EGR valve, fuel injectors
11- wht/blu - vehicle speed sensor pin 2
12- grn/blk - ECU pin 22
G2
1 - grn/blk - oil temp sensor
2 - wht/red - outside air temp sensor
3 - blu/wht - coolant temp sender
10- yel - high oil pressure warning switch
11- blu/blk - low oil pressure warning switch
H1
1 - red/blk - ignition switch pin 50
2 - red - ignition switch pin 30
3 - blk/yel - ignition switch pin X
4 - blk - ignition switch pin 15
5 - blk/blu - indicator stalks 4pin plug pin 4
6 - brn - wiper stalk 4pin plug pin 3
7 - brn/red - ignition switch pin S, radio pin 4
8 - grn/red - wiper stalk 4pin plug pin 2
9 - grn/wht - wiper stalk 4pin plug pin 1
H2
1 - brn/blu - indicator stalk 7pin plug pin 1
4 - blk/grn - indicator stalk 7pin plug pin 7
6 - blk/wht - indicator stalk 7pin plug pin 3
8 - blk/wht/grn - indicator stalk 7pin plug pin 2
J
1 - wht - indicator stalk 5pin plug pin 4
2 - wht/blk - indicator stalk 5pin plug pin 3
3 - yel - indicator stalk 5pin plug pin 2
- yel/blu - DRM relay resistor?
4 - red/yel - indicator stalk 5pin plug pin 5
5 - grn - wiper stalk 5pin plug pin 3
6 - brn/blk - wiper stalk 5pin plug pin 5
7 - blk/gry - wiper stalk 5pin plug pin 2
8 - wht/yel - indicator stalk 5pin plug pin 1
9 - grn/blk - wiper stalk 5pin plug pin 4
10- grn/yel - wiper stalk 5pin plug pin 1
« Last Edit: 19 October 2010, 10:12 by rubjonny »
Re: Fusebox FAQ
« Reply #25 on: 27 November 2008, 10:06 »
K
1 - blk/wht - rear left indicator
2 - gry/red - right rear lights
3 - gry/blk - left rear lights
4 - red/blk - brake lights
5 - gry/grn - rear number plate lights, rear ashtray light
6 - blk/yel - rear wiper motor pin 1
7 - blk/grn - rear right indicator
8 - blk/blu - reverse lights
9 - grn/blk - rear wiper motor pin 3
11- brn - rear ashtray light, 'earth claw'?
12- wht - rear screen heater
L
1 - brn - handbrake warning switch pin 2
2 - gry - left door switch pin 1
4 - blk/grn - left seatbelt switch pin 1
5 - red/blk - boot light
6 - brn - handbrake warning switch pin 1
- ? - DRL diode
7 - red/blk - electric sunroof control module pin 5, sunvisor mirror light, front & rear interior lights, central locking control module pin 1
M
1 - brn - fuel pump
2 - red/yel - fuel pump
3 - vio/blk - fuel level sender pin 2
5 - blk/wht - sunroof light switch pin 1, right front map/reading light
N
1 - red/wht - rad fan thermal switch pin 2, coolant control module pin 3, rad fan pin 2
2 - red/wht - A/C pressure switch pin 4
3 - red - auxilery fuse #23 (30amp)
4 - yel - A/C pressure switch pin 2
5 - blu/wht - A/C switch pin 7, ECU pin 39
6 - blk/yel - bridged to pin Q/2
P
1 - gry/yel - fog light switch pin 83a
2 - blk/yel - rear window heater switch pin 4
3 - wht/grn - rear window heater switch pin 3, heated mirror elements
4 - gry/blu - fog light switch pin 83
5 - brn - rear screen heater switch pin 31
7 - gry/blu - rear screen heater switch pin 1
Q
1 - brn - glovebox light pin 1, boot light pin 2, cigarette lighter pin 1, A/C switch pin 3, blower light pin 2, diagnostics plug pin 1, boot release switch pin 2
2 - blk/red - bridged to N/6, Blower switch pin 2, coolant control module 8pin plug pin 4, A/C thermal switch/engine coolant temp warning switch pin 2
3 - red/wht - cigarette lighter pin 2, radio pin 7, boot light switch pin 1, diagnostic connector pin 2, boot release switch pin 1
6 - gry/blu - blower switch pin 1, A/C switch pin 5, cigarette lighter pin 3, radio pin 6
R
2 - gry/blk - headlight switch pin 58L
4 - brn - headlight switch 58b
5 - red/yel - headlight switch pin 11
6 - gry/red - headlight switch pin 58R
7 - gry/grn - headlight switch pin 58
8 - brn - headlight switch pin 31
9 - wht/blk - headlight switch pin 2
10- blk/yel - headlight switch pin X, DRM relay pin 4
S
1 - blk/gry - wiper motor pin 1, heated washer jets
2 - grn - wiper motor pin 4
3 - brn - wiper motor pin 5
4 - grn/blk - wiper motor pin 3
5 - grn/yel - wiper motor pin 2
U1
1 - wht - Dash plug pin 17 (oil temp sensor)
2 - wht - Dash plug pin 19 (outside temp sensor)
3 - wht - Dash plug pin 8 (oil pressure control unit - feed from 1.8 bar)
5 - wht - Dash plug pin 9 (oil pressure control unit - feed from 0.3 bar)
6 - wht - Dash plug pin 10 (rev counter)
7 - wht - Dash plug pin 1 (outside temp sensor)
10- wht - Dash plug pin 3 (earth)
11- wht - Dash plug pin 27 (speedo signal)
12- wht - Dash plug pin 21 (fuel gauge)
14- wht - Dash plug pin 12 (dash & digital clock bulbs)
U2
1 - wht - Dash plug pin 13 (ignition live feed)
2 - wht - Dash plug pin 7 (cruise control unit pin 5, 2.0 16v motronic control unit pin 2?)
4 - wht - Dash plug pin 15 (stalk memory switch pin 2)
5 - wht - Dash plug pin 2 (coolant low level sender)
7 - wht - Dash plug pin 25 (main beam warning light)
8 - wht - Dash plug pin 6 (stalk memory switch pin 3)
9 - wht - Dash plug pin 23 (coolant temp gauge)
10- wht - Dash plug pin 18 (handbrake warning light)
11- wht - Dash plug pin 11 (permanent live feed from fuse #21)
12- wht - Dash plug pin 16 (alternator warning light)
13- wht - Dash plug pin 5 (earth to cylinder head)
14- wht - Dash plug pin 4 (stalk memory switch pin 4)
V
1 - red/wht - MFA mode select switch
2 - brn/wht - MFA switch earth
3 - blu/yel - MFA switch memory select/reset
4 - yel/red - MFA switch memory select/reset
W
1 - blu/wht - vehicle speed sensor junction connector
2 - gry/blk - ABS relay pin 3, ABS module pin 52
4 - wht/red - ABS module pin 32
- blk/red - Cruise control clutch & brake pedal switch pin 1, transmission control module pin 26
X
2 - blk/yel - airbag control light pin 4, ABS warning pin 2
4 - blk/yel - airbag control light pin 2
8 - yel/red - ABS warning light pin 1
Y
1 - brn/blu glow plug timer module pin 5
2 - electric windows, park/neutral psition relay pin 2
3 - Red - Battery +ve, Junction connector TV2
Z1 - red/blue - fuel injectors
Z2 - brn - battery -ve
Junction connector TV2: (Permanent live feed direct from battery - 30)
Y/3
alarm control module 6pin plug pin 3
alarm control module 10pin plug pin 1
left/right central locking trigger motors pin 2
alarm/central locking/boot lock switch pin 4
alarm system indicator light pin 2
left/right door warning lights pin 2
ECU pin 54
fuel evap relay pin 2
Junction connector TV4: (Ignition live, from coil -15)
E/2
D/8
alarm module 10pin plug pin 4
shift lock solonoid pin 2
transmission control module pin 19
cruise control/transmission range switch pin 5
Airbag control module pin 5
cruise control range switch pin 5
Transmission control module pin 23
Junction connector TV5: (Ignition live, from coil -15)
D/9
D/11
cruise control/transmission range switch pin 4
left/right rear electric window switches pin 1
A/T console light
cassette storage light
transmission control module pin 38
electric mirror switch pin 6
heated seat switch pin 3
heated seat control modules pin 8
electric window control modules pin 7
PCV heater
Junction connector TV6: (Ignition live, from x-over relay -X)
D/3
Coolant fan control module T10a/9
3rd speed coolant fan switch pin 2
Junction connector TV8: (Dash lights feed)
D/12
heated seat switch pin 1
electric mirror switch pin 2
front electric window switches pin 1
electric window switch console pin 4
cruise control transmission range switch pin 4
A/T console light
Junction connector TV11: (Brakes on feed)
W/4
Diesel DFI ECU pin 44
Junction connector TV13: (Vehicle speed sensor)
W/1
cruise control module pin 7
ECU pin 65
Junction connector TV15:
left door warning light
left door contact switch
Junction connector TV18: (Ignition live, from x-over relay -X)
D/3
ABS control module pin 23
Diagnostics junction box 1: (Transmission control Diagnostics feed)
ECU pin 21
Diagnostics junction box 2: (ECU Diagnostics feed)
diagnostics plug pin 2
ECU pin 43
transmission control module pin 6
ABS control module pin 42
« Last Edit: 19 October 2010, 10:11 by rubjonny »
Offline monzablue16v
Re: Fusebox FAQ
« Reply #26 on: 23 June 2009, 20:59 »
Thanks RJ knew this was here somewhere :) should help with the old 1.8t swap :)
Offline demos
Re: Fusebox FAQ
« Reply #27 on: 06 January 2010, 02:17 »
Thanks ALOT RJ! I was starting to get desperate till I found this! I believe I have the most abused GTi here. I bought it as a second car till I finish a BMW dream project of mine. I finished the project over a year ago but couldn't sell the GTi, I kept remembering how faithful it was to me. Folding seats down and throwing in bumpers, huge spare parts...etc. I couldn't have finished the project without her. So today I decided to fix her up a bit and it seemed like I've opened a can of worms. The loom is raped :(
I was wondering if you guys would know which old version of Elsa would cover my 87 GTi?
Re: Fusebox FAQ
« Reply #28 on: 08 January 2010, 10:51 »
I dont think there is an electronic copy of elsa that will cover that model fully, they all had paper back then :P
Re: Fusebox FAQ
« Reply #29 on: 30 January 2010, 21:37 »
Well that list has come in useful but I still have loads of random plugs spare behind my fusebox all ones and two's and a really odd three pin one. just a case of tracing them I suppose :)
