Author Topic: 1.8 turbo engine differences???  (Read 21382 times)
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
Re: 1.8 turbo engine differences???
« Reply #10 on: 10 July 2006, 16:14 »
Looking at what you're going to get done, your probably only going to get about 205 hp (+/- 5 hp) with the AGU, & about 230 (+/- 5 hp) with the AUM.
Wish I'd researched/stumbled accross this about a year ago.  I probably would of got a newer model with higher miles, rather than an older one with low miles!
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Offline topher
  • Administrator
  • fully functioning
« Reply #11 on: 10 July 2006, 16:33 »
Thanks for that topher spot on :wink:
But, i dont think i will be goin for the big turbo... maybe in few years time but its not an option for me at the moment. All i will be doing, is ss exhaust (de-cat maybe :undecided:) Air filter and re-map. Plus few other things..... i want to get it up to about 250bhp that bout it for now..
So would i be best with a AUM or a AGU for this ? (forgettting about the big turbo :smiley:)
Regards
Ryan :wink:
You'll never get a REAL 250bhp out of either of those engines on their standard turbos, without using nitrous. With filter, exhaust, decat and 4bar fpr, fully mapped to suit.. you'll be knocking on 230. K04 turbo upgrade would give you a nice reliable 250-260 bhp without stressing the engine. It really doesn't matter which base engine you start with, like i said strength-wise all the golf engines are the same. You might get a bit more power at the sacrifice of some torque with the AGU head.
Next person to say the AGU is stronger gets to wear the dunces cap :grin:
« Reply #12 on: 10 July 2006, 16:44 »
Quote
I say the last person!   :tongue:
Offline topher
  • Administrator
  • fully functioning
« Reply #13 on: 10 July 2006, 16:48 »
the agu engine is stronger
okay :grin:
« Reply #14 on: 10 July 2006, 17:01 »
:grin:
Offline Phil_M
« Reply #15 on: 10 July 2006, 20:02 »
AGU also has the larger 20mm Piston pins.
GOLF 1.9T AGU TD05H 18G
http://smg.photobucket.com/albums/v218/pipmann30/GOLF%20GTI%20%20TURBO/?albumview=slideshow
Front wheel drive monster 0-60mph in under 5sec 0-100mph in 10sec
Offline topher
  • Administrator
  • fully functioning
« Reply #16 on: 11 July 2006, 11:05 »
The "vag technician" who tried to sell me 19mm rods for my AGU has just received an email slap. i r teh dunce.
Offline Dizzie
  • Make friends with your fast
« Reply #17 on: 12 July 2006, 23:52 »
they all have 20mm pins apart from the AUQ (19mm). I found this out the hard way when I went to install BAM pistons into my AUQ lump and ended up having to buy new con rods to fit. great excuse to get forged ones though :D
The AGU lump has the larger valves yes. This only becomes beneficial at 300bhp+. Before that the small valve heads actually produce better results. I could go into why this is, but I'll save it for a talk around a BBQ sat in a field ;) There are people saying the AGU has a forged crank rather than a cast one. I've never heard of anyone snapping a crank...
As with all the k03 (and sport) turbo'd engines you'll only get 210bhp from them regardless of your special intakes or miltek exhausts. The NBDW engines will get better results than the DBW ones that's a fact.
personally if you have the intention of doing more than an air filter and exhaust buy a NDBW 150 lump.
Mk4 Golf 150PD
