Author Topic: HOW TO: MK5 GOLF Nokia Car Kit PART 2  (Read 39293 times)
Offline The Doc
  • M2 DCT / 335d Xdrive / Vito Sport
« on: 20 May 2006, 20:09 »
Next remove the heater controls and place them on their side for easy access - donÂ’t unplug it though!
ok now pull the gear lever surround upwards
then undo the 2 screws holding the ashtray in place
Then place your remote button from the control unit  where you would like it and feed the wires beneath the ashtray and retrieve them at the rear of the air con control unit.
then replace the ashtray, screw the screws back in & replace the gear stick surround
MAKING CONNECTIONS
Ok next we take the RADIO (FEMALE) end of the adapter lead and insert the plugs that we removed from the radio loom
then insert the RADIO end of the adapter into the radio
next plug the cars radio loom into the adapters other (male) plug
then push the wiring loom into the dash, out of the way but leave the CAR KIT wiring hanging out.
next feed all remaining car phone wiring through to the rear of the radio bracket and out of the air con bracket
FEEDING THE MIC WIRE THROUGH
The next phase is to feed the mic wire from the cubby to the air - con bracket area - tape the 2 highlighted wires together
and feed the wires behind the dash up to the rear of the heater controls
MAKING FINAL CONNECTIONS
ok now simply plug all your connectors into the CAR KIT CONTROL UNIT
then fix the unit at the rear of the heater controls using Velcro etc - then push the radio back into place
There should be 1 wire left waving around - the blue one you cut off the loom at the beginning - this provides the car kit with the switched ignition supply that it needs - strip around 1cm of the insulation off.
then join it to pin 20 of the heater controls - a black wire with a blue tracer - if this is not present then find an ignition live using a multi meter.
the unit is now functional - pair up your bluetooth phone and test it!
when using your phone the radio will now show phone or telephone, mute your radio and the speech from your call will be played through your front speakers!
REASEBLE THE CAR!  :cry:
« Last Edit: 28 June 2006, 23:36 by The Doc »
Offline illyun
Re: HOW TO: MK5 GOLF Nokia Car Kit PART 2
« Reply #1 on: 20 May 2006, 22:37 »
bloody hell. how long did it take for you to figure all that out?
Mk1 GTI Campaign, Mk5 GTI Edition 30, Mk6 GTI (Coming Soon...)
Offline The Doc
« Reply #2 on: 20 May 2006, 23:07 »
It normally takes about 45 mins!
the first one took me about 1-2 hours
But it took 3 hours to fit that one today coz of all the pics - plus its my baby  :smiley:
« Last Edit: 20 May 2006, 23:15 by The Doc »
Offline Wardinho
« Reply #3 on: 21 May 2006, 13:52 »
I had nightmares last night about you ripping apart your car like that. What if you pulled too hard and you broke a bit!! doesn't bare thinking about
Offline Dom Mk3
  • Insert wit here
« Reply #4 on: 22 May 2006, 09:17 »
Doc,
I think you need to stress how important it is to keep the microphone wire away from the a-pillar airbags. If someone were to take a shortcut when routing the wire and get parts behind the pillar trim it's gonna be a tad dangerous in a crash :nerd:
Good work! :cool:
Offline The Doc
« Reply #5 on: 22 May 2006, 19:38 »
OK  :grin:
Air bag bit ammended for the brain dead out there - thanks  :wink:
Please don't have nightmares fella - all the bits cost buttons to replace if ya feck 'em plus I never had any part of a Golf snap on me! Unlike some other cars I could mention!  :wink:
Glad I've helped - Let me know if anyone tries fitting one!
« Last Edit: 22 May 2006, 19:56 by The Doc »
Offline Tal
« Reply #6 on: 26 May 2006, 21:16 »
Excellent guide I am going to have a go but my kit is a sony one and needs a positive, negative and ignition on cable any idea where I can get these from ??
Tal
Offline Dom Mk3
  • Insert wit here
« Reply #7 on: 26 May 2006, 21:39 »
you can still use the stereo interface leads... I've got some with sony erricson adapters... looks like the doc might have too!
Offline The Doc
« Reply #8 on: 26 May 2006, 23:04 »
Yup the interface lead is the best way to get them or you can cut into you wires on the rear of the radio - Do you have climate control or manual air-con?
I don't sell these items so ask Dom if he can supply you with one!  :wink:
« Last Edit: 26 May 2006, 23:13 by The Doc »
Offline Dom Mk3
  • Insert wit here
« Reply #9 on: 27 May 2006, 00:45 »
okey doke then... £20 to golf gti members  :wink:
