Author Topic: OBD, VAGCOM, Fault Codes. What they mean and probable causes.  (Read 75075 times)
Offline Jazzbluebora
Re: OBD, VAGCOM, Fault Codes. What they mean and probable causes.
« Reply #40 on: 22 September 2012, 17:24 »
hiya i have a set of S3seats which i want to fit to my 03 plate bora tdi as well as momo steering wheel can i turn the airbag light off and de activate the air bag light completely ive just bought the vagcom rosstech so any help would be great before i start thanks terry
jockgti
« Reply #41 on: 06 February 2013, 15:05 »
is there a list like this anywhere with reasons why the stop warning flashes?
Offline budgie
code p0411.   i know what it is the question is how do i cure it???
Offline th3_f15t
01271 – Positioning Motor for Temperature Flap (V68) – static – Faulty
00849 – S-contact at ignition Starter Switch (D) – static – Undefined switch condition
I've got known issues with my cooling fans not coming on, the previous owner has wired them to be on permanently. If I remove the "fix" will this clear up this fault and show up what's really stopping the fans from kicking in?
Second fault I'm clueless and need a starting point or possible, cheap solution.
Moving over to Flickr, sorry for the broken picture links!
Offline itavaltalainen
Sure that the first fault code is radiator?
Sounds like motor for aircon flap rather than radiator.
S-contact is likely the ignition switch
Seat Leon ST FR DSG on order :)
