Author Topic: OBD, VAGCOM, Fault Codes. What they mean and probable causes.  (Read 92685 times)
Offline DJGTi
Re: OBD, VAGCOM, Fault Codes. What they mean and probable causes.
« Reply #30 on: 22 January 2010, 14:50 »
Got code 01537 P0601
Internal Contr Module Memory
Check Sum Error
Static
Dealer says I need a new ECU @ £800!
Can anyone help?
Offline Rhyso
« Reply #31 on: 22 January 2010, 14:52 »
Give R-Tech a ring :afro:
They should be able to confirm if this is the case or not.  May even have a 2nd hand ECU kicking around if thats the case  :smiley:
Offline mowlamb
  • MK4 GT TDI 130 - DERV POWER!!
Address 01: Engine       Labels: 038-906-019-ASZ.LBL
   Controller: 038 906 019 FG
   Component: 1,9l R4 EDC G000SG  1470
   Coding: 00002
   Shop #: WSC 01271
   WVWZZZ1JZ2W475862     VWZ7Z0A4543808
2 Faults Found:
17965 - Charge Pressure Control: Positive Deviation
            P1557 - 35-10 - - - Intermittent
17667 - Coolant Circulation Valve (N214): Short to Ground
            P1259 - 35-10 - - - Intermittent
Readiness: N/A
VCDS-Lite Version: Release 1.0
Thursday, 27 May 2010, 09:10:17:0
Control Module Part Number: 1C0 959 799 B
  Component and/or Version: 1X Komfortgerát HLO 0003
           Software Coding: 00258
            Work Shop Code: WSC 01271
           Additional Info: 1C2959802A  1X Tõrsteuer.FS KLO 0004
           Additional Info: 1C2959801A  1X Tõrsteuer.BF KLO 0004
           Additional Info: 1C0959811A  1X Tõrsteuer.HL KLO 0004
           Additional Info: 1C0959812A  1X Tõrsteuer.HR KLO 0004
1 Fault Found:
01135 - Interior Monitoring Sensors
        36-00 - Open Circuit
ANy more info on these faults would be much aprreciated  :smiley:
Offline Mad_vdub_mk4
Hello mate jut wondering if you could tell me what this means and how to fix it
17633// p1225: cyl.1-fuel inj circ short to ground
17634// p1226: cyl.1-fuel inj circ short to ground
17635// p1227: cyl.1-fuel inj circ short to ground
17636// p1228: cyl.1-fuel inj circ short to ground
cheers Dude  :grin:
Offline sthompson121
« Reply #34 on: 29 October 2011, 12:55 »
Hi, i drive a VW bora tdi 03', i recently took an odd notion of cleaning my intercooler and related pipes. however when i put it all back togeather, the car will only drive in limp mode. im geting an error code (18263 data bus drive software condition monitoring (data bus drive). i cant find anywhere what this means....i am new to the forums and wold appreciate if anyone could give me advice on what i have done and how to fix. is it going to cost me?
much appreciated
Offline Swiftsam
« Reply #35 on: 14 January 2012, 17:52 »
Hi I have been getting two codes and there doesn't seem to be anything helpful online so far, can anyone help?
00610
Ignition Output 2
Static - Output Open
And
00609
Ignition Output 2
It's had a new coil pack about six months ago, replaced the plugs and leads today, still not convinced it's not the coil pack, but if it isn't what else could it be?
Regards Sam
Offline Swiftsam
« Reply #36 on: 14 January 2012, 17:53 »
Forgot to say 2000 1.4S Golf AHW
Offline aussiebob
« Reply #37 on: 31 January 2012, 09:39 »
Hiya,
Got these on a MK4 1.6 5 door.
Wednesday, 25 January 2012, 12:52:37.
Chassis Type: 1J - VW Golf/Bora IV
Scan: 01,02,03,08,15,16,17,19,22,29,35,36,37,39,46,47,55,56,57,75,76
Address 01: Engine       Labels: 06A-906-019-AEH.LBL
   Controller: 06A 906 019 BQ
   Component: 1.6l 2V/R4 SIMOS HS3120
   Coding: 00031
   Shop #: WSC 00028
   VCID: 73995CCF52BB
2 Faults Found:
00513 -  Engine Speed Sensor (G28)
            27-10 -  Implausible Signal - Intermittent
00668 - Shareware Version. To Decode all DTCs
            36-10 - Please Register/Activate - Intermittent
Readiness: N/A
Address 03: ABS Brakes       Labels: 1J0-907-37x-ABS.LBL
   Controller: 1J0 907 379 P
   Component: ABS     20 IE CAN  0001
   Coding: 03504
   Shop #: WSC 00028
   VCID: 3E0FBDFB2979
No fault code found.
Any Help will be appreciated.
Offline jonnybell
« Reply #38 on: 05 February 2012, 11:21 »
I cant find the switch on the drivers side that controls the interior and door card lights, I need to check it as they dont work when door is opened, however they do work when opening the passengers side.
Where is the switch ?? Any help welcomed !!!!!
Offline richw911
« Reply #39 on: 05 February 2012, 13:08 »
Post in the main section next time  :wink:
Its built into the door http://www.golfgtiforum.co.uk/index.php?topic=86403.0
