Author Topic: ETKA part numbers - Post queries here - Often trimmed down  (Read 94236 times)
Re: ETKA part numbers - (just a trial at the mo)
« Reply #20 on: 24 April 2006, 14:35 »
Gambit:
191 853 515 D  2BC - protection strip for door - left
191 853 516 D  2BC - protection strip for door - right
both discontinued though :(
« Last Edit: 28 April 2006, 13:28 by Slick#13 »
« Reply #21 on: 24 April 2006, 19:31 »
Frog:
191 711 173 B - MK2 relay shaft - £30.46 +VAT
« Last Edit: 28 April 2006, 13:29 by Slick#13 »
Offline gti jim
  • return of the vac...
« Reply #22 on: 23 May 2006, 20:29 »
any idea what the part number is for the hose wrapped in gaffer tape and israeli handcuffs in the picture below
heater matrix hose ^^^^^^
191 819 373 D (to be cut to length)
« Last Edit: 10 November 2006, 14:43 by Pedro Muchacho... »
« Reply #23 on: 25 May 2006, 10:10 »
GSF is the best place for these, I'd remove the bypass valves altogether:
18004 HEATER HOSE (FEED) 8v - £9.45
18004B HEATER HOSE(FEED) 16V - £11.50
18005 HEATER HOSE (RETURN) All - £9.45
If you don't want to bin the valves you can just buy the required hose and cut to length :)
« Reply #24 on: 30 May 2006, 17:47 »
FAO: Stan Deezy
1. If its blue, has 2 pins and is a push fit into the coolant hose flange on the front of the block, then its famous blue sender, see part number earlier in this post :)  If it has a screw thread, then I THINK its this one:
035 919 369 M - thermal switch, white, digifant - £25.19+VAT
2. 171 121 407 F - Square tank - £23.29+VAT
1H0 121 407 A - Round tank - £26.95+VAT
3. 443 121 321 - Square tank cap - £8.78+VAT
1H0 121 321 C - Round tank cap - £5.42+VAT
4. With a bit of fiddling yes, the brackets are different.  The old bracket is spot welded to the suspension turret and the new bracket bolts on.  The level sender plug is different also so you'll need to chop one off a later VW and solder it onto your loom.
5. If you mean hoses from GSF, mine have been fine for nearly a year now, cant see any degredation. From VW:
191 819 373 D - Return hose - £14.82+VAT
191 819 371 E - Feed hose - £16.80+VAT
« Last Edit: 30 May 2006, 19:24 by Slick#13 »
« Reply #25 on: 30 May 2006, 18:22 »
FAO: Pegasus
1. 027 129 717 F - upper gasket - £10.15+VAT
037 129 717 F - lower gasket - £3.19+VAT
2. 035 133 554 - lower insert for injector - £1.41+VAT
034 133 555 A - upper insert for injector - £3.19+VAT
035 133 557 - injector insert seal - £0.87+VAT
3. 037 133 073 A - t'body gasket - £2.14+VAT
« Last Edit: 30 May 2006, 19:26 by Slick#13 »
« Reply #26 on: 05 June 2006, 08:13 »
044 103 609 D - sump gasket - £18.23+VAT (how much?! Get one from http://www.vwspares.co.uk instead!)
N  902 716 02 - allen key head bolt (combi) - £0.38+VAT
026 198 025 C - rubber rocker cover gasket kit w/ studs - £9.00+VAT (actually cheaper for the kit than it is to buy the gasket on its own!?)
« Reply #27 on: 18 June 2006, 17:38 »
037 133 382 - plastic angled connecting piece, MK2 8v Digifant ISV hose -> inlet boot - £2.86+VAT
« Last Edit: 31 July 2007, 23:09 by rubjonny »
« Reply #28 on: 19 June 2006, 14:32 »
321 877 209 A - sunroof seal - £36.50+vat
No hall sender listed for the digifant dizzies :(
« Reply #29 on: 08 July 2006, 07:08 »
You are correct!
357 601 025 M - 6Jx15 ET35 - £33.66+vat
321 601 025 H - 6Jx14 ET38 - £34.48+vat (CL,GL chrome couloured?)
191 601 025 K - 6Jx14 ET38 - £29.97+vat (GTI)
