Author Topic: ETKA part numbers - Post queries here - Often trimmed down  (Read 58307 times)
Re: ETKA part numbers - (just a trial at the mo)
« Reply #10 on: 16 March 2006, 12:26 »
Anti slim jim plates for the doors (will fit both front & rears):
191 837 273 - rip plate - left - £3.07
191 837 274 - rip plate - right - £3.07
Basically what you do is unbolt the door lock block, and it slips into the hole.  They only go in one way, which becomes obvious when you do it as there are 2 holes in it that the bolts pass through :)
As you know, quoted prices don't include VAT :smiley:
« Reply #11 on: 16 March 2006, 12:41 »
The slim jim plates are listed for:
89-95 Scirocco/Corrado
90-92 Golf/Jetta (must have been a later part, it will defo fit earlier MK2s as well)
88-97 Passat/Santana
To be clear these arn't the Armour Door Plates you get which fit around the outside door handles, these go inside the door and protect the lock mech from Slim Jims :)
Offline TC
« Reply #12 on: 24 March 2006, 13:21 »
oil pressure censor '92 MK2 8valve
056 919 081 C (0.15 - 0.45 bar)
Like the code that Slick#13 put down but slightly different.
Hope this helps
Offline dscam
« Reply #13 on: 25 March 2006, 01:13 »
Protect foils (black vinyl trim strip) for under side skirts on '90 spec Mk2 Gti's:
Left = 193 853 805
Right = 193 853 806
Offline dscam
« Reply #14 on: 25 March 2006, 01:14 »
Ignition lead router/tidy (as fitted to manifold on Mk3 - may fit Mk2)
037 905 497 (not shown on ETKA)
Offline Gambit
    • My Golf
« Reply #15 on: 29 March 2006, 11:17 »
right if been fishing around looking for part number for the VAG reducer pipe
so ive think ive found it here. part number 18 on diagram. can someone try & find the part number for it!!
http://www.vagcat.com/epc/cat/vw/GOSY/1989/67/50/710986/#18
part 2 on this one
http://www.vagcat.com/epc/cat/vw/GO/1989/92/50/1033859/
its a dual clip
NB: THIS DOES NOT WORK AS A REDUCER PIPE!!!
« Last Edit: 05 April 2006, 12:46 by Gambit »
« Reply #16 on: 29 March 2006, 14:42 »
191 253 141 F - dual exhaust clip MK2 8v downpipe -> front silencer - £7.36+VAT :)
« Last Edit: 31 July 2007, 23:13 by rubjonny »
Offline Gambit
    • My Golf
« Reply #17 on: 05 April 2006, 12:45 »
more numbers!
http://www.vagcat.com/epc/cat/vw/GO/1990/110/56/1095238/
numbers
16: bellow
17: cover cap
« Reply #18 on: 05 April 2006, 13:06 »
191 971 916 A - front door cable rubber bellows - deleted
191 837 865 - cover cap end of front door - 46p+VAT
« Last Edit: 31 July 2007, 23:14 by rubjonny »
« Reply #19 on: 05 April 2006, 23:33 »
PAS belt splash guard kit:
191 825 250 A 01C - cover (big bumper models) - v-belt - £20.29+VAT
191 825 250   01C - cover (small bumper models) - v-belt - £20.29+VAT
N   901 066 01 - snap nut - £0.36+VAT (x2 only for small bumber guard)
Also need:
N   015 946 1 - hex head pannel screw - £0.29+VAT (2 needed for small bumpers, 1 for bigs)
N   902 076 01 - washer - £0.41+VAT  (2 needed for small bumpers, 1 for bigs)
N   043 885 1 - hex head pannel screw - £0.29+VAT
N   011 665 3 - washer - £0.10+VAT
811 807 577 C - nut insert - £0.32+VAT
« Last Edit: 01 May 2007, 19:11 by rubjonny »
