Author Topic: Parking sensors on wheel arch  (Read 559 times)
Offline Kenis
« on: 28 March 2021, 23:54 »
Has anyone noticed a lot of the YouTube euro vid cars have a sensor on the wheel arch basically on the side of the car? I’ve not seen that on any uk spec cars. Is it just an extra sensor if park assist is installed?
E.g. https://youtu.be/Z6tvO5WL28w (at 2min 16 sec)
Vw history:
‘09 Mk 6 GTi 3 door, grey, 19s, loaded, sold due to baby
‘82 Mk 1 GL(? Was >20 yrs ago) 5 door, green
‘72 Beetle
Current: family crossover and 50% of 2010 Caterham 7 Roadsport 150
Offline mcmaddy
Re: Parking sensors on wheel arch
« Reply #1 on: 28 March 2021, 23:57 »
Yes they are for park assist. You get four extra sensors, two rear and two front.
Offline Kenis
« Reply #2 on: 29 March 2021, 00:10 »
Thank you!
Vw history:
‘72 Beetle
Offline Wrex22
« Reply #3 on: 01 April 2021, 08:45 »
Has anyone got park assit? What’s it like in terms of not curbing alloys on a parallel park?
Offline fredgroves
« Reply #4 on: 01 April 2021, 09:18 »
It was always not too bad, leaving quite a reasonable gap but of course it can only cope if the space is actually parallel - if its on a curve, it could dink it.
Offline SRGTD
« Reply #5 on: 01 April 2021, 09:19 »
I think in all the time I’ve been on VAG forums (probably 10+ years), most of those who’ve spec’d park assist have used it only a handful of times, which IMHO probably means it has an entertainment value but after it’s been used a few times is seen as a bit of a gimmick. The Golf isn’t an large car, and with dipping kerbside mirror and parking sensors, it should be fairly easy to park in most situations, including parallel parking, without needing park assist.
I may be wrong but with parallel parking, I think on the mk7 / mk7.5 park assist uses the position of the vehicles in front and behind the intended parking space and how they’ve parked as reference points. If those vehicles have parked badly (wheels mounting the pavement or alloys ‘kissing’ the kerb), then park assist will attempt to park your car in a similar fashion. Park assist technology may have moved on, so the risk of alloy wheel damage when parallel parking if surrounding vehicles are poorly parked may no longer be an issue. I’ve certainly not read of any instances with the mk8 Golf of kerbed alloys as a result of poor or inaccurate assistance from park assist, although i suspect it’s probably not a particularly popular option, in which case no reports of alloy damage is likely to be the result of a low take up rate.
It’s not an expensive option at £200, but I think I’d be looking to spend that £200 elsewhere.
« Last Edit: 01 April 2021, 11:11 by SRGTD »
Gone but not forgotten;
2016 Polo GTI; Blue Silk
Offline mcmaddy
« Reply #6 on: 02 April 2021, 00:10 »
Yes you are right SRGTD. It uses the parked cars and if they've parked just on the kerb then Park Assist will try and follow suit. It's still a great piece of tech for the money though.
