Author Topic: ABS fault now Traction control  (Read 5006 times)
Offline smallzoo
« on: 27 February 2021, 09:08 »
I bought a 2002 Gti a few months ago. Drives well then about 3 weeks ago the ABS light came on. Went to one garage they plugged it in and said ABS pump fault so needs replacing ..mega expensive.
I decided to find someone else, they said yes it said ABS fault but they replaced the fuse box above the battery ant it went away. They said they had seen that before so cost me £25+labour
All great for about 2 weeks now the ABS light is not on but the traction control light instead
Any ideas ?
Wish I knew someone who was a golf gti expert in and around Sandbach , Cheshire ?
Offline richw911
Re: ABS fault now Traction control
« Reply #1 on: 08 March 2021, 11:49 »
Are your brake lights working?...
Offline bgbazz
  • If it aint broke...I can fix it!
« Reply #2 on: 08 March 2021, 13:43 »
Richw911 is on the right track. It seems the MK4 has some strange warning light systems...my ABS light came on, quite a while back and it turned out to be the brake light switch, just above the pedal. You could do a search and find my post, if you like...maybe 3 years ago.
Hope that will help you.   :smiley:
Mk4 Golf TDI Estate 4Motion, remapped 1.9. Sweet runner = keeper. She is the 66th vehicle I've owned and hopefully, the last.
Offline Mr_Orange
« Reply #3 on: 08 March 2021, 16:21 »
Same here. I recall it's a fiddly fix. Buy genuine
Build thread clicky
