Author Topic: control module incorrectly coded 01044  (Read 1599 times)
Offline ramrod
« on: 24 January 2021, 15:34 »
driver window stopped working, press the button and got a loud whirring noise so swapped the motor and it now goes up and down but i have lost my wing mirror indicator and i get "control module incorrectly coded" 01044 error code
how do i recode the the driver door module? i have obdeleven and can do long coding with that, if i only knew the process :shocked:
thanks in advance
Mk6 Gti - current daily
Mk3 16v Anni - retired daily now parked on 200,300 miles
Offline Bellend
Re: control module incorrectly coded 01044
« Reply #1 on: 24 January 2021, 17:54 »
A lot of the time you can use the Rosstech guides and slowly work your way around with other scan tools.
Can't comment on OBD 11.
Can you plug the old module in to get the coding off of that?
Where all my moneys went.
Offline ramrod
« Reply #2 on: 25 January 2021, 10:36 »
yes mate i spent a few hours googling and figured out how to code the door module all good now and was surprisingly very easy on obdeleven, a few steps less than vcdsguide :whistle:
thanks for the reply all the same!
