Author Topic: GOLF GTI M6 DSG PROBLEM  (Read 1758 times)
Offline mattyr
« on: 06 January 2021, 13:13 »
Please can anyone advise on the following 2010 gti dsg mk6 at around 1500rpm im getting a jerk feeling in 2nd -6th once above that rev range its clears ? i have changed coil pack and plugs and no change
many Thanks
Offline Snoopy
  • Moderator
  • Geoff.
Re: GOLF GTI M6 DSG PROBLEM
« Reply #1 on: 09 January 2021, 15:22 »
Could be any number of things.
 Is it boosting ok or does it feel like its doing it in steps. The diverter valve causes that.
Mk6 GTI  &  Mk1 GTI
34 years of GTI ownership.
Offline mattyr
« Reply #2 on: 12 January 2021, 15:29 »
hi all working well apart from that little stutter mentioned
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #3 on: 13 January 2021, 12:01 »
Maybe worth removing the diverter valve and checking its not split.
Does the engine have any oil leaks at bottom of gearbox or round the intake air pipes?
Mk6 GTI  &  Mk1 GTI
Offline mattyr
« Reply #4 on: 14 January 2021, 12:11 »
no none of those its annoying almost like a misfire/hesitation but clears when rev over that ?
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #5 on: 14 January 2021, 19:27 »
As said could be any number of things to name a few, carbon build up on intake manifold flaps, injectorss, fuel filter, maf, diverter valve, crankcase breather valve, etc etc. Best way would be to first get it scanned to see if any codes. Then maybe get it put on vcds,vagcom by someone with it and do some measurements to see what maybe out. Maybe have a word with a vw specialist in your area that may have come across it before.
Mk6 GTI  &  Mk1 GTI
Offline mattyr
« Reply #6 on: 15 January 2021, 08:32 »
many thanks for advise if you know any trusted ones close to wv7 please ?
