Author Topic: Headlight issues. (not working)  (Read 2064 times)
Offline Hazimaro
« on: 18 December 2020, 19:04 »
Hello,
Golf gti mk6 2011 2.0
- both head lamps main lights are not turning on when switched on. However when turning on the indicators, the bulbs flash as per. The small strip light bellow the main bulb does switch on to.
Sorry guys, I have no knowledge on electrical work ect. Could this be the main switch where I turn to select the lights? Or a fuse?
Offline Snoopy
  • Moderator
  • Geoff.
Re: Headlight issues. (not working)
« Reply #1 on: 18 December 2020, 19:08 »
Fuse box is on the side of the dash. Remove the side panel and check the fuse list to see which is headlights.  Probably just the fuse for the headlights. Sounds like the sidelights are still working just not the headlight. The fuse list and hiw to get to them is in the handbook.
Mk6 GTI  &  Mk1 GTI
34 years of GTI ownership.
Offline Hazimaro
« Reply #2 on: 18 December 2020, 19:14 »
Thanks snooops, going to try this out on Sunday. Fingers crossed
Offline Hazimaro
« Reply #3 on: 19 December 2020, 12:38 »
Snoops I inspected the fuse they are fine, what is the next potential?
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #4 on: 19 December 2020, 17:30 »
Need to check bulbs then get someone with a multimeter to check if they have voltage. Maybe find someone who has VCDS Vagcom scan tool to see if any failts logged. As odd both are off unless the computer has switched them off for some reason due to a fault.
Mk6 GTI  &  Mk1 GTI
