Author Topic: MK 5 GT TDI DSG GEARBOX FAULT  (Read 3924 times)
Offline holdk2
« on: 11 November 2020, 19:56 »
Hi guys, can i ask a question my 2008 mk 5 gt tdi dsg box is faulty if i set off in D it will go through the gears fine until it gets into 3 then it will rev to about 4500/5000rpm then change and sometimes not change at all,
I can sometimes be traveling at 60/70 and it will change down into 5th, when I'm slowing down to come to a junction/roundabout it will judder as if it's changing down the gears  "feeling like I'm tapping the brake", however it works fine when i pop it manual it go's through the gears fine, I'm puzzled as there is a engine management light on tho.
I had fresh oil & filter in the gearbox about 4 months ago.
Any ideas pls.
Offline jv
  • Administrator
Re: MK 5 GT TDI DSG GEARBOX FAULT
« Reply #1 on: 27 January 2021, 19:20 »
Checking the fault codes is probably a good start.
Buy site stuff!
GolfGTI.co.uk - merchandise
Support the forum charity!
