Author Topic: Mk3 GTI 16v ABF running faults  (Read 4820 times)
Offline Vwgolfgti83
« on: 20 July 2020, 22:04 »
I’m having a few issues with my 16v, it has developed an intermittent misfire. I’ve Owned the car for 6 years now and in that time most stuff has been changed but only recently it’s started to misfire. The one thing I’ve noticed and it’s always done this, is the car cranks for about 3 seconds before starting, not sure if it’s normal or not. I recently replaced the crank sensor and fuel pressure regulator and since the car now has a misfire. Plugs leads and coil have all previously been replaced. Would like to do a fault code read but being OBD1 it’s a bit tricky. Anyone had any similar faults?
Offline ramrod
Re: Mk3 GTI 16v ABF running faults
« Reply #1 on: 26 July 2020, 19:11 »
plug a code reader in?
Mk6 Gti - current daily
Mk3 16v Anni - retired daily now parked on 200,300 miles
Offline Vwgolfgti83
« Reply #2 on: 27 July 2020, 20:56 »
Difficult to read the fault memory as it’s obd1 and most fault code readers only work on obd2
Offline ramrod
« Reply #3 on: 29 July 2020, 21:18 »
oh ok, my 16v has odb2 :rolleyes:
Offline ramrod
« Reply #4 on: 31 July 2020, 23:29 »
could be a vacuum leak..check ecu & fuel pump relays too, if you changed the crank sensor then maybe it needs tightening?? was it a cheap one bcos they dont last long at all
