Author Topic: Anyone used a obdeleven for brake adaption??  (Read 2796 times)
Offline gti fly bye
  • VW MK4 GT TDI, ITS A SMOKEY ALTERNATIVE!
« on: 29 June 2020, 18:46 »
Had the traction control light on for a while and did a scan with
Obdeleven...
Brakes
Software number: 1K0907379AC
Software version: 0101
Hardware number: 1K0907379AC
Coding: 0021121
Trouble codes:
01435 - Brake pressure sensor 1 no or incorrect basic setting/adaptation
static
00778 - Steering angle sensor no or incorrect basic setting/adaptation
static
01423 - Lateral acceleration sensor no or incorrect basic setting/adaptation
static
I've checked the live data and the brake pressure sensor is actually working but I think I need to preform a a basic settings on it for some reason.
Has anyone used the obdeleven for this, i found information on vcds but not for the obdeleven?
Any help would be appreciated...
BEAT ANY GTI (TOWING A CARVAN, UPHILL)
Offline itavaltalainen
Re: Anyone used a obdeleven for brake adaption??
« Reply #1 on: 01 July 2020, 08:28 »
You can do, same procedure as with VCDS.
Only the GUI is different.
