Author Topic: Boot lock issues  (Read 5363 times)
Offline Mk3jordio
Boot lock issues
« on: 30 April 2020, 18:57 »
So I've brought a new boot lock by topran as my original barrel was seized so the key wouldn't go inside. This meant I could only open the boot with the central locking. Now I've fitted the new boot lock I can unlock by the key however I can't lock it by the key. Anybody know what's gone on?😅😂 I will add that I can unlock with the key if I turn it all the way to the right and push in at the same time
Offline WeekendMechanic
  • Golf MK3 GTD
Re: Boot lock issues
« Reply #1 on: 30 June 2020, 06:47 »
I think you may have a metal rod missing check to see if it has come undone somewhere inside
Offline ramrod
« Reply #2 on: 31 July 2020, 23:33 »
mine did this all the time until i applied a duct tape modification :grin:
@Mk3jordio pull the cover off inside the tailgate & press the lock/unlock buttons on your key, you will see the rod & where it has popped out from
Mk6 Gti - current daily
Mk3 16v Anni - retired daily now parked on 200,300 miles
