Author Topic: Mk4 GTi starting issue  (Read 7293 times)
Offline barrym381
Re: Mk4 GTi starting issue
« Reply #10 on: 20 April 2020, 14:11 »
could it be the Crankshaft sensor , Ive read a few incidents online that sound similar to my issue ..?
It could be a number of things as said get yourself a cheap version of vcds and that will check for fault codes
Offline DAR400
« Reply #11 on: 20 April 2020, 17:27 »
does the MK4 have a 16pin OBDII compliant plug and system .. I was was looking at an ANCEL VD500 unit to buy.
Offline barrym381
« Reply #12 on: 20 April 2020, 17:39 »
Yes and those code readers won’t do much more than read and clear fault codes a cheap version of vcds will let you do that and more  :smiley:
Offline DAR400
« Reply #13 on: 20 April 2020, 17:42 »
I cant find one that works with Mac OSX !
Offline DAR400
« Reply #14 on: 20 April 2020, 17:57 »
can you point in the right direction for a VCDS please, not sure I'm looking in the right place as the ones Ive found from Ross-Tech are £300-400
Offline DAR400
« Reply #17 on: 21 April 2020, 11:58 »
thank you very much , Ill check them out :grin:
