Author Topic: Strange noise when braking  (Read 5010 times)
Offline james2
  • No scammers please.
« on: 14 April 2020, 18:40 »
When slightly braking going down a hill and turning left there's a horrible sound like the brake pad has fallen apart. I can not see whats making the noise, any ideas ?
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline barrym381
Re: Strange noise when braking
« Reply #1 on: 14 April 2020, 20:04 »
Whip the wheel off to check
Offline james2
« Reply #2 on: 15 April 2020, 20:06 »
Proberly wont do it if i remove the wheel. It only does it when you turn slighty left and brake hardish. It fine if i drive at 30mph. I think it could be the wishbone as it looks strange where it bolts onto the body. Im going to get some new brake pads and hope i see something when i change them.
Offline barrym381
« Reply #3 on: 15 April 2020, 22:10 »
If the pad has fallen apart you’ll see it and while it’s off you can inspect the wishbone better
