Author Topic: Carista - available options  (Read 11665 times)
Offline Mutley75
Re: Carista - available options
« Reply #30 on: 19 March 2020, 00:29 »
I have the beta but it took me hours to list all the options on the paid version! So far as I can tell it’s just variations of existing settings. The one I really want is to toggle Stop/Start so that it’s off by default but apparently VW doesn’t support this. You can only hack it to stop it ever kicking in, which I also don’t want as I do use it very occasionally.
Golf GTi Performance Edition (2019), 5dr, DSG in Isaac Blue, Dynaudio & Brescia alloys.
Offline Vwjap
« Reply #31 on: 19 March 2020, 11:34 »
Dv52 and others make a control board (yes I know it’s just a homemade one) that switches the stop start off at startup, wires in to the switch, I did think of a arduno to make it memory but never got round to fitting it
Offline kmpowell
« Reply #32 on: 19 March 2020, 11:43 »
Carista is a great little device! I’ve been wanting to make a few changes to the car, but I’m all Apple, so getting OBD11 involved extra costs, and I’d just put it off. For £15.99 I’ve done all the changes I wanted - as long as I remember to cancel my subscription before 21st of February!
What I did today was:
1. Soundaktor volume down to zero. (Seems to make a big improvement to in car refinement.)
2. Show A/C blower speed when in AUTO.
3. Scandinavian DRL: daytime running lights also activate taillights. (Never saw the sense of just fronts!)
4. Lane-change turn signal auto-flasher count set from 3 to 5.
5. Puddle lights while driver-side mirror is folding.
6. Puddle lights while passenger-side mirror is folding.
7. Configured beep when locking/unlocking and enabled menu in car settings.
8. Headlight washer activation delay set to maximum 2.5 seconds and frequency to every screen wash.
The only problem I had was that to change the number of lane change flashes you need to reset the lights to factory settings. There is a note in the app about this, which I failed to follow for a few frustrating attempts. Once I did that the change to 5 happened. Altogether very satisfying and great value for money.
Is there a way to stop the DRL's dimming when the headlights are on?
SOLD March 2021
Offline Talk-torque
« Reply #33 on: 19 March 2020, 13:50 »
I don’t recall that option being there, just sidelights operate DRLs, so they are not dimmed with sidelights on. Just checked mine, and the DRLs dim with headlights on. I seem to recall that VCDS will alter the %age of dimming. OBD11 may also have this option. Don’t see the need myself.
Roger.
Offline Vwjap
« Reply #34 on: 19 March 2020, 16:34 »
as far as I’m aware it depends on what headlights you have, the newer u headlights don’t support this
Offline mistac
« Reply #35 on: 27 March 2020, 21:09 »
I have enabled the  alarm chirp beep bit  on locking and unlocking et cetera. In the vehicle settings on the infotainment section there is a bit that says “acoustic confirmation of central locking or similar” ? Is that the menu option that you can use on the infotainment system to turn it on or off or am I missing the on off menu option? Cheers
GTI 7.5 Performance 5dr DSG Tornado Red - completely standard spec as - it comes out of the tin as they say
Offline Vwjap
« Reply #36 on: 27 March 2020, 23:18 »
That’ll be it, “acoustic confirmation on central locking”on mine
« Last Edit: 27 March 2020, 23:20 by Vwjap »
Offline Talk-torque
« Reply #37 on: 28 March 2020, 06:52 »
That’s the one!
Roger.
Offline wrighty79
« Reply #38 on: 08 April 2020, 04:26 »
For those who are interested, I have noted down each available customisation option on the Mk 7.5 GTI.  I've only listed the top level menus and not all of the options/sub-menus as there are quite a lot, but you get the general idea.  Bare in mind, some of these options are already enabled by default for the GTI.  The app can configure lesser model Golfs which may not have these options on the dash display.
Chassis & Engines
  - Disable auto start/stop system
  - Soundaktor volume
  - Power steering default mode
  - Throttle response behaviour
can u change the colours of the digital dash like with obd 11 as thats the main one im wanting?
  - ESC/ASR
Dings & Warnings
  - Seat belt warning
  - Speed warning at 75mph
  - Ding when key left in ignition
Driver Assist
  - Dynamic start assist
  - Hill start disengagement
Heater & A/C
  - Remember recirculating air state
  - Show A/C blower speed when in Auto
  - Temperature adjustment for hot countries
Instruments: Display & Nav
  - Gauge needle sweep at startup
  - Developer menu in MMI holding Menu button for 10 seconds (Discover Pro only)
  - Start screen logo (infotainment)
  - Start screen logo (instrument cluster)
  - Microphone sensitivity
  - Driver information system (DIS) display
  - Allow enabling oil temperature display via MMI
  - Oil temperature display
  - Efficiency program display
  - Refuel quantity in MFD
  - Telephone menu display
  - Battery charge display
  - Navigation compass display
  - Compass display position
  - Ambient temperature display
  - Allow 'Car' settings in MMI while car is in motion
  - Allow 'Tuner' settings in MMI while car is in motion
  - Allow 'Media' settings in MMI while car is in motion
  - Allow 'Phone' settings in MMI while car is in motion
  - Show 'Follow traffic regulations' disclaimer in infotainment
Instruments: Language & Units
  - Time display format
  - Date display format
  - Temperature display units
  - Distance display units
  - Speed display units
  - Consumption display units
  - Pressure display units
  - Volume display units
Lights: Coming/Leaving Home
  - Coming home lights
  - Coming home lights mode
  - Coming home lights use...
  - Coming home lights duration
  - Leaving home lights step 1/2
  - Leaving home lights step 2/2
  - Leaving home lights duration
Lights: Daytime Running Lights (DRL)
  - Daytime running lights
  - Allow configuring DRLs via dash display
  - Scandinavian DRL (activate taillights and parking lights)
  - Turn off DRLs when parking brake is on
  - Parking light activates DRLs
  - DRLs on only when switch is set to Auto
Lights: Exterior
  - Lane change turn signal auto-flasher
  - Lane change turn signal auto-flasher count
  - Auto headlights activation threshold
  - Turn off front fog lights when high beams are on
  - Flash rear fogs along with flash-to-pass when headlights are on
  - Flash rear fogs along with flash-to-pass when headlights are off
  - Flash brake lights in emergency stopping
  - Flash brake lights in emergency stopping phase 2
  - Flash hazard lights in emergency stopping
  - Puddle lights driver side
  - Puddle lights passenger side
  - Puddle lights while driver-side mirror is folding
  - Puddle lights while passenger-side mirror is folding
  - Left cornering light (using front fog)
  - Right cornering light (using front fog)
  - Cornering lights activation
Locking: Automatic
  - Auto-lock doors when moving
  - Auto-unlock doors when key is taken out of ignition
  - Auto-unlock doors when shifting into park
  - Car lock and trunk lid close (and lock) via easy close button
Locking: Beep & Blink
  - Allow configuring beep when locking/unlocking
  - Beep when locking with remote
  - Beep when unlocking with remote
  - Menu for configuring beep when locking/unlocking
  - Beep when locking/unlocking doors comes from the... (choose from Alarm or Horn)
Locking: Smart Key (KESSY)
  - Auto-lock when doors are closed and smart key is outside vehicle (step 1/2)
  - Auto-lock when doors are closed and smart key is outside vehicle (step 2/2)
Mirrors
  - Allow auto-folding mirrors
  - Auto fold side-view mirrors
  - Allow configuring auto-folding mirrors on dash
  - Auto-fold mirror via...
  - Allow lowering passenger-side mirror when in reverse gear
  - Lower passenger-side mirror when in reverse gear
  - Menu for lowering passenger-side mirror when in reverse gear
  - Synchronous mirror adjustment menu on dash
Parking Sensors
  - Park distance visualisation
  - Beep when parking sensor activated
  - Rear parking sensor beep volume
  - Rear parking sensor beep tone
  - Front parking sensor beep volume
  - Front parking sensor beep tone
Seats & Steering Wheel
  - Auto-activate steering wheel heater
  - Remember driver-side seat heater level
  - Remember passenger-side seat heater level
Trunk
  - Pop trunk via remote
Windows & Sunroof
  - Enable setting for opening/closing windows and sunroof
  - Allow configuring open/close windows with remove via dash menu
  - Open windows via long-press on remote (step 1/2)
  - Open windows via long-press on remote (step 2/2)
  - Close windows via long-press on remote (step 1/2)
  - Close windows via long-press on remote (step 2/2)
  - Open sunroof via long-press on remote
  - Close sunroof via long-press on remote
  - Sunroof action when opening via remote
  - Blink turn signals when done closing windows via remote
  - Allow power window operation after ignition is turned off
Wipers & Washer
  - Speed dependent windshield wiper speed
  - Headlight washer activation delay
  - Activate headlight washers once every x times the windshield washer is used
Other
  - Windshield heater runs for duration of x minutes
  - Rear window heater runs for duration of x minutes
  - Enable remote control buttons when ignition is on
Offline Mutley75
« Reply #39 on: 25 April 2020, 13:26 »
Carista have just launched a new ‘Low Power Mode’ for the battery if your car isn’t being used much. This basically just enables the manufacturers Transport Mode to conserve power. As soon as you start the engine, it reverts to normal power mode. You need the beta version to take advantage of this option. Full details and other useful tips can be found here ... https://blog.caristaapp.com/preserve-your-car-battery-with-a-low-power-state-enabled-with-carista-70e7f7354522
