Never thought I'd do it but here we are
My Golf is being broken up at the end of the month so parts are up for sale after the 31st of Jan
AGU engine and gearbox, single mass conversion but cannot guarantee clutch, 81k - £300
Carbonio CAI with G-Reddy mushroom filter relocated to bumper - £30
K03s turbo with lines and Forge adjustable actuator with yellow spring - £140
THS front mount intercooler with all pipework - £200
AGU ECU with R-Tech Stage 2+ custom remap, needs VR6 MAF and C20LET yellow injectors to run plus other supporting mods - rolling roaded at 225bhp - £150
AGU ECU with R-Tech custom remap, needs VR6 MAF housing and Bosch big greens plus other supporting mods to run - rolling roaded at 280bhp - £150
Bosch big green injectors - £100
C20LET yellow injectors - £100
VR6 MAF housing with working AGU MAF sensor - £40
2.5" non resonated stainless exhaust with twin tailpipes - £150
3" decat - £40
Audi S3 washer bottle cover - £30
Later spec battery cover - £10
Silicone boost hoses - £40
Audi TT gearbox mounted short shift - £10
Saikou Michi Stage 3 catch can - £40
SFS supersize TIP - £60
Badger5 ported exhaust manifold - £40
Genuine TFSI coilpacks - £20
Walbro 255LPH in-tank fuel pump - £20
Colour coded 4motion rear valance - £30
Colditz dealer plate surrounds, pair - £10
Aero wipers - £10
Mk5 Golf door mirrors with dynamic LED repeaters - £70
Depo angel eye black projector headlights with twin LED amber indicators and HID kit - £100
Smoked US side markers in rubstrip - £20
T5.5 rear boot handle - £20
18" Mk5 Golf Monza replica wheels painted in Alfa Romeo Grigio Carbon, all tyres 6mm - £300
10mm Eibach spacers with longer bolts - £30
15mm bolt on FK spacers with bolts - £40
Seat Leon Cupra R Brembo 4pots with brand new never used 323mm discs and Brembo pads, braided brake lines to suit mk4 Golf - £300
256mm calipers and carriers with Brembo pads - £50
Custom intermediate braided rear brake lines - £20
Silver/black Net Optic dash parts with Anniversary style door handles (4 door) plus window switch with chrome tips - £50
Red/white boost gauge in black A pillar pod - £10
Blue LED door pin lights - £5
Anniversary interior light with W8 style LED downlights - £20
Bora vents, illuminated with loom - £50
Audi TT pedals - £20
Audi TT rear view mirror - £10
Beetle Sport door aluminium pins - £10
Full FIS Custom Passat Instrument cluster with white/red LED backlights and Mk7 Golf needles; miles to empty, lit needles/gauges, welcome message and needle sweep activated - £100
Passat mirror switch - £30
R32 style door triggers and handles - £10
Bluetooth auto headlight kit - £10
Genuine Anniversary sunvisors with vanity light switches, all working perfectly - £60
Genuine Anniversary black rear window surround - £20
Black non ultrasonic rear passenger lights - £20
Black Anniversary vanity lights - £15
FK AK Street coilovers with front spring covers - £100
Audi S3 upper front strut brace - £30
Audi S3 lower front strut brace - £20
Rear strut brace - £20
Whiteline adjustable rear ARB - £50
Whiteline adjustable front ARB - £50
Audi TT cast wishbones with cookbot adapters and 30mm poly front bushes, Superpro caster adjust poly bushes (early type with tapped nubs for standard drop links - £100
Audi TT hubs - £50
Audi TT Roadster subframe with solid bushes - £30
Supersport shorter poly top mounts - £10
Audi S3 steering rack - £50
PSI Tuning poly rear spring caps - £10
ABF single mass flywheel and VR6 XTD carbon kevlar clutch with all bolts needed, complete single mass conversion - £100
Polyflex red bushed dogbone mount - £20
B&M replica short shift gear stick kit with lift up reverse and Richbrook leather gearknob - £30
Also for sale is a K04 turbo with manifold and brand new actuator - £200
K04 oil/water lines - £50
Creation Motorsport 3" silicone TIP in black with adapter - £80
Rebuilt AGU engine with H section rods, supertech valve stem seals, new oil pump, rings, light skim on the head, head gasket, crank oil seal, cam belt, water pump. All bolts and gaskets renewed throughout and torqued to manufacturers spec. Ready to drop in - £400
Devils Own water/meth injection kit. Solenoid, mappable controller, pump, tank with level sensor and nozzle in throttle body sandwich plate - £250
Epytec rear caliper spacers for 4WD or FWD Mk4 Golf platform cars; Cupra R, R32, S3, 1.8T, Octavia vRS. Allows the use of 310mm Phaeton front discs on the rear. Brand new and never fitted. Includes a brand new set of Phaeton discs redrilled to 5x100 and spigot rings - £100
Excellent condition 5 door Recaro interior with 3x 3 point seat belts in the back (no lap belt in the middle). Hardly any wear to bolsters, bottom foam of drivers seat replaced a few years ago. Drivers seat is always covered - £200
Genuine 5 door roof bars with Thule wind deflector - £100
S3 space saver - £10
Wings, doors and any other plastics odds and sods also available by request
All parts plus postage
Please drop me an email if anything appeals to you or you would like some pics while the parts are still in the car
