Author Topic: mk6 golf dab aerial module  (Read 4788 times)
Offline rolys
« on: 16 June 2019, 21:09 »
hi
my wifes got a mk6 golf gt tdi and i've fitted a chinese pumpkin android head unit with dab. i want to use the fitted rear windscreen arial if possible. i think i'm correct in thinking that to use the rear windscreen aerial for dab you need a dab/fm module in the boot. does anyone know if it's just a case of swapping this over with the fm module that's already there and using the existing cable from module to radio and then use some sort of adaptor at the radio to fit the usb dab box end that also puts 12v down to power the module?
or is it not that simple, any advice appreciated.
