Author Topic: White Golf Help/Advice Please?  (Read 5125 times)
Offline Tally Wacker
« on: 04 June 2019, 10:50 »
Ok, so I have a 67 Oryx White GTI.
Currently my cleaning routine is..
Snow Foam + Rinse
Wash with AG Bodywork Shampoo + Rinse + Dry
G3 Clay Mitt + Rinse
AG Magma + Rinse + Dry
AG SRP (by hand)
Bilt Hamber DSW
Raceglaze Wheel Sealant.
I find it really hard to see where the SRP & DSW are on the white surface & no matter how careful I am I always seem to leave some behind.
So any ideas on helping with that with different products maybe & any advice on improving my routine in general would be very welcome.
Offline hog_hedge
Re: White Golf Help/Advice Please?
« Reply #1 on: 04 June 2019, 16:03 »
Unless you’re planning to machine polish then I would omit the clay mitt stage and include a tar removal stage using Autosmart Tardis or something similar. Claying will cause marring that you wouldn’t be able to fix by hand, you will just mask it using the SRP.
If you want the best life out of the DSW I would also omit the SRP stage and add in a panel wipe stage before applying DSW. However, if you’re happy with the longevity with DSW over SRP then leave it as it is.
Other than that it seems pretty good to me, my routine is as follows.
Clean wheels
Snow foam
Rinse
Shampoo car
Rinse & dry
Tar remover on car and alloys
Rinse
Fallout remover on car and alloys
Rinse
Shampoo car
Rinse and dry
Panel wipe
Apply wax/sealant to car
Apply wheel sealant
If I decide to machine polish then I would clay after the fallout remover and machine polish before the final panel wipe ready for applying my wax or sealant of choice.
This whole routine usually only gets done 1-2 times a year.
« Reply #2 on: 04 June 2019, 16:43 »
Cheers mate. appreciate your help.
Offline kmpowell
« Reply #3 on: 04 June 2019, 18:23 »
I wouldn't bother with SRP. SRP has a mild cutting agent in it, so it's good for bringing paint back to life, but not as a regular application, it'll do more damage than good. As hog_hedge ays, omit the SRP and concentrate on the final waxing.
Too much drying also damages paintwork/surfaces, so try to bin one of the drying processes you do.
SOLD March 2021
« Reply #4 on: 04 June 2019, 18:42 »
Cheers guys.
If I dump the SRP is there something else I can/should use before the wax stage?
Thanks
Offline hog_hedge
« Reply #5 on: 04 June 2019, 20:13 »
Drying is the hidden hologram maker for paint that's for sure! I sheet as much water off with an open ended hose and pat the remaining drops dry. My neighbours think I'm nuts and I'm nowhere near as hardcore as some folks over on DW :laugh:
Offline kmpowell
« Reply #6 on: 05 June 2019, 12:40 »
I thoroughly recommend these for drying: https://amzn.to/2KBWF9x
They are huge (5sq ft!) and you can lay them out flat, they soak up 8x their weight in water(!) without any need to wipe or swipe creating spiderwebs/holograms. Cheap as chips too...  :smiley:
SOLD March 2021
Offline Jim_mk7.5
« Reply #7 on: 02 July 2019, 09:13 »
Snow Foam + Rinse
AG SRP (by hand)
Bilt Hamber DSW
When you say cleaning routine, how often are doing this lot?
NOW - 330e M Sport
« Reply #8 on: 07 July 2019, 11:48 »
Sorry for delay
Doing this around every 2/3 months
Kit changed now..
Auto Finesse Citrus Power (Bug & Grime) + Rinse
Snow Foam + Rinse
Bilt Hamber Korrosol + Rinse + Dry
AG SRP (by hand)
AG Ultra HD Wax
Weekly...
Snow Foam + Rinse
Auto Finesse Finale QD
Offline BobbyT
« Reply #9 on: 07 July 2019, 19:05 »
I like a nice wax or sealant on my oryx, really helps it to pop in the sun. When buffing just try to use the light to see where you haven't been. Maybe stand back a bit too and have a look around the car at the end, then just buff anything you've missed.
