Author Topic: **MK4 GOLF 20V TURBO AUM ISSUES HELP**  (Read 6514 times)
Offline davkav
Re: **MK4 GOLF 20V TURBO AUM ISSUES HELP**
« Reply #20 on: 07 August 2019, 14:35 »
And I agree, first port of call should always be get the car scanned. There is a lot to gained from reading fault codes or logging sensor data.
I never said it was explicitly a head gasket failure, but from there description it does sound like one. You implied that because you have never experienced it throughout the 35 variants of 1.8T that you have owned, that it simply cannot happen. Just because you have experienced 'crazy temperatures' from the exhaust gasses and never experienced a head gasket failure because of it, has no bearing on whether or not it can happen to a modified or standard car.
Offline barrym381
« Reply #21 on: 07 August 2019, 14:58 »
Any part can fail I'm not that stupid but a head gasket doesn't just go there's always a reason why it's overheated in the first place that should always be checked first before even trying to diagnose a gasket failure
Offline davkav
« Reply #22 on: 07 August 2019, 15:01 »
You are contradicting yourself there.
You need to find the problem first before you can diagnose why it happened....
Offline barrym381
« Reply #23 on: 07 August 2019, 15:25 »
No I'm just not guessing what the problem is with the ops car
Offline davkav
« Reply #24 on: 07 August 2019, 15:30 »
And neither am I. I am merely going on the OP's description of the problem and then my own experience. I am offering up my suggestion of what I think the problem is, nothing more. I am not asking them to jump straight in and pull the head on the car. I am suggesting they look into a potential gasket failure for the source of there problem. They need to find the problem first before they can go looking for what caused it.
Offline barrym381
« Reply #25 on: 07 August 2019, 15:35 »
Well if you read it correctly you would have seen the post about the white dust how many coolants do you know that are white  :grin:
Offline davkav
« Reply #26 on: 07 August 2019, 15:37 »
This is my last post about this because obviously, only your opinion matters.
You have obviously never seen coolant boil over, spill/spray outside the expansion bottle and dry up. It leaves a white powdery residue behind akin to what the OP is describing.
Offline barrym381
« Reply #27 on: 07 August 2019, 15:43 »
My opinion was to get the car scanned by someone that knows what there doing
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #28 on: 14 October 2019, 19:41 »
*click*
