Author Topic: Urgent help possible dead car :(  (Read 7383 times)
Offline Perryd84
  • MK4 Golf 1.8T 20V GTI
« on: 08 February 2019, 13:19 »
Hi all long time since i've had to post on here but i need some expert help!
So couple weeks ago my AGU gti started running lumpy with no power. Turned out it was the ignition amplifier which sorted that issue. Along with this i changed the spark plugs as they needed doing anyway.
Week later driving along changed gear and the engine died! Wont start! Back in the garage they changed the cam sensor and it started. Drove home cut out dead again!
So the garage came out to the car and saw a fuse had blown so changed that got it running then bang it died again. Another fuse blown! The garage are washing their hands of it saying the amount of work to find whats wrong is not worth it on a car this old!
Need some desperate help! Is it worth taking it to the dealers or shall i cut my losses and break it? :cry:
1999 GTI 20V 1.8T AGU : Stage 1 Map : Forge Split-r (Full recirculate) : Forge TIP : Pipercross Viper CAI : 40mm Apex lowering springs : Custom interior trim : 2009 Ibiza sport Gear Knob : Custom Mats : bora sport instrument cluster : Bora Vents :
VAGCOM - South London only
Offline Simeon
Re: Urgent help possible dead car :(
« Reply #1 on: 08 February 2019, 16:54 »
Have you had it scanned to see if there's any fault codes?
I'm sure there'll be a common issue for these, isn't there a box by the battery with a load of power connections that get water in and cause issues sometimes ... might have made that up re Mk4s mind
Don't take it to a dealer, it'll cost you a fortune
Offline Perryd84
« Reply #2 on: 09 February 2019, 19:12 »
VCDS Version: Release 11.11.3
Data version: 20120401
Saturday,09,February,2019,18:31:21:32264
Chassis Type: 1J - VW Golf/Bora IV
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
          76
   Mileage: 153160km/95169miles
Address 01: Engine        Labels: 06A-906-018-AGU.lbl
   Part No: 06A 906 018 R
   Component: 1.8L R4/5VT MOTR HS D06
   Coding: 04000
   Shop #: WSC 00028
   VCID: 31630B1DFB327B1
No fault code found.
Readiness: N/A
Address 03: ABS Brakes        Labels: 1J0-907-37x-ABS.lbl
   Part No: 1J0 907 379 H
   Component: ABS/EDS 20 IE CAN  0001
   Coding: 13504
   Shop #: WSC 00028
   VCID: 36693801125C5C9
Address 15: Airbags        Labels: 1J0-909-60x-VW3.lbl
   Part No: 1J0 909 609
   Component:  A AIRBAG VW3 SG   0002
   Coding: 00065
   Shop #: WSC 00028
   VCID: ECDD5A699C90569
1 Fault Found:
00532 - Supply Voltage B+
            07-10 - Signal too Low - Intermittent
Address 17: Instruments        Labels: 1J0-919-xxx-17.lbl
   Part No: 1J0 919 931 B
   Component: A4-KOMBIINSTR. VDO V01
   Coding: 04442
   Shop #: WSC 00401
   VCID: 2D5B176DE70A1F1
   Subsystem 1 - Part No: IMMO
   Component: IDENTNR: VWZ7Z0X1404810
   IMMO-IDENTNR: VWZ7Z0X1404810
Address 46: Central Conv.        Labels: 1J0-959-799.lbl
   Part No: 1J0 959 799 AH
   Component: 4V Zentral-SG Komf. 0001
   Coding: 00256
   Shop #: WSC 00028
   VCID: 840D12C99400BE9
   Subsystem 1 - Part No: 1J2959802C
   Component: 4V T��euerger. FS0002F
   Subsystem 2 - Part No: 1J2959801D
   Component: 4V T��euerger. BF0002r
5 Faults Found:
00953 - Interior Light Time limit
            25-10 - Unknown Switch Condition - Intermittent
01134 - Alarm Horn (H12)
            49-00 - No Communications
00943 - Heated Exterior Mirror; Driver Side (Z4)
            35-00 -  -
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
            27-00 - Implausible Signal
00944 - Heated Exterior Mirror; Passenger Side (Z5)
            35-00 -  -
End   --------------------------------
Offline Perryd84
« Reply #3 on: 09 February 2019, 19:15 »
So just got it on the scanner results above.
I know the passenger door doesnt work on central locking and the alarm horn doesnt sound all the time these issues have been on going for years!
Not sure about the airbag issue the voltage thing is usually if the batterys been unplugged right?
No codes in the engine!??! Baffled!!
Offline bgbazz
  • If it aint broke...I can fix it!
« Reply #4 on: 09 February 2019, 20:38 »
I cop some silly stuff with my MK4 from time to time as well and this is what I always do first...
Remove the battery leads and give them a good clean...leave them off for about 20 mins or so. Flip the lid on the black plastic box that sits on the top of the battery and check that all the connections are clean and tight...any problems in there will be very obvious.
Make sure there is no moisture in that box and give it a good dose of WD40 before closing it again.
Then I trace back any and all leads from that top box and make sure they are connecting properly to whatever they component or earth they are supposed to. You might be surprised at what you find!
Re connect the battery, start up and go for a drive...keep your fingers crossed. May not solve your problem, but it won't cost you anything to try.
 :smiley:
Mk4 Golf TDI Estate 4Motion, remapped 1.9. Sweet runner = keeper. She is the 66th vehicle I've owned and hopefully, the last.
Offline Perryd84
« Reply #5 on: 11 February 2019, 12:08 »
So the crap garage I took it to have finally told me what fuse keeps blowing.
It's the ECU fuse. Changed the ECU with my old one and the same thing happens.
It seems once the car is under load it blows the fuse!?
MAF is fine, lambda is fine, ignition amp is brand new, coils are fine (although one does get really hot)
Really need help on this
« Last Edit: 12 February 2019, 12:59 by Perryd84 »
Offline Dalo Harkin
« Reply #6 on: 19 February 2019, 16:11 »
I'd be looking at the cam sensor they changed first, most of the time its what work was done most recent that causes an issue.
Take it you gapped the plugs right etc?
Offline Perryd84
« Reply #7 on: 26 February 2019, 11:35 »
All fixed now and she's back on the road!
Turned out to be faulty wiring to the coil packs which kept blowing them and subsequently shorting out other systems. The garage I took it to got though 6 brand new coils before figuring it out.
Glad she's fixed now and back :grin:
