Author Topic: 2018 GTI PP Isaac Blue 7.5 3 door .. GTechniq treatments completed  (Read 3543 times)
Offline Mutley75
Re: 2018 Isaac Blue 7.5 3 door .. back in the GTI World
« Reply #20 on: 06 February 2019, 20:11 »
This - https://www.raceglaze.co.uk/car-care-exterior/wash/race-glaze-maxi-water-filter-large-25litre/
Swear by it. Worth it’s weight in gold. In particular hard water areas.
Golf GTi Performance Edition (2019), 5dr, DSG in Issac Blue with rear camera, keyless entry, Dynaudio, Brescia alloys & Dynamic LED headlights.
Offline Jim_mk7.5
« Last Edit: 06 February 2019, 20:35 by Jim_mk7.5 »
NOW - 2018 Mk7.5 GTI Performance 5dr DSG, Tungsten Silver
GONE - 2017 Mk7.5 GTI 5dr DSG, Indium Grey
Offline Yusee
« Reply #22 on: 06 February 2019, 20:47 »
I may wash less frequently until the paint hardens.
It’s a great colour though, and a brilliant car!
I’m not sure the paint will get any harder?
Are you using a snow foam or citrus pre wash?
I’m not- i’ve thought about snow foam, perhaps I should.
There isn’t anything visible on first look, I just don’t don’t want things to get worse.
What is a citrus pre wash?
The idea of using a snow foam and optionally a citrus based pre wash as well is to loosen and lift most of the dirt before you touch the car. Touching a dirty car with a wash mitt will create swirls (not as much obviously as a closed cell sponge) but snow foaming a car with a good sealant on means the wash mitt part is not really picking up much dirt at all - crucial at this time of year as the car is halfway to been clean already after a powerwash rinse.
Thanks for the explanation, Jim.
I’ll start snow foam, before I cause any real damage.
I hope this isn’t the start of a slippery slope, there’s no limit to what can be done to keep the car pristine!
Previously, still missed - 1991 205 Gti 1.9
Offline Mutley75
« Reply #23 on: 06 February 2019, 21:47 »
Wow, that's pricey  :shocked:
If you really need a water filter - https://www.theultimatefinish.co.uk/aqua-gleam/30ppm-de-ionising-water-filter-12.aspx
RaceGlaze is better than the AquaGleam. 0ppm vs 30ppm and the resin lasts longer too. A must in my area otherwise the car looks like it’s been washed in water and flour!
Offline Snoopy
  • 28+ years of GTI ownership.
« Reply #24 on: 07 February 2019, 19:32 »
9 years of dark Shadow blue = no issues = Valet pro snow foam + dodo born to be mild.
Mk1 GTI, Mk6 GTI, Mk1 Leon & 4 non VW.
Offline kmpowell
« Reply #25 on: 08 February 2019, 12:05 »
most of my self-inflicted swirls/holograms have happened during the drying process.
This. On cars that do not have any protection on them, this is where the vast majority of the swirling takes place, even if you use a really soft drying towel. You can snow-foam, prewash etc etc, but if you're lazy and/or don't have the time to stand in your driveway for half a day, just get the car and wheels ceramic coated and then when you maintenance wash it the dirt and water just glides off.
My routine and stuff, there's really no need to spend lots:
1. Power jet-wash to lift the dirt and get rid of the surface debris.
2. '2-bucket' wash with PH neutral shampoo, and wash-mits.
3. Slow/Flood jet-wash rinse
4. Dry what water is left (normally very little) with a large drying towel that has some of THIS sprayed onto/into it to ensure the ceramic coating stays in its best possible form.
« Last Edit: 08 February 2019, 12:16 by kmpowell »
Offline SRGTD
« Reply #26 on: 08 February 2019, 13:40 »
Yes, a poor drying technique can inflict damage. I like to minimise contact with the paintwork during the drying stage.
I’ve got a warm air dryer that I use to blow the final rinse water off the car. If the car is well protected, blowing off what rinse water is left leaves very few droplets to pat dry with a good quality absorbent drying towel. A warm air dryer is also very good at removing the water from all those annoying water traps too, some of which can continue to drip for some time after you’ve finished drying the car (door mirror housings, grilles, door handles, window rubbers, wheel bolt holes etc.).
2016 Pocket Rocket Polo GTI 5dr manual, Blue Silk, Jacara tartan seats, Sports Performance Kit, Climate Control, Convenience Pack, Parking Pack, VW Motorsport Alloys in anthracite.
Gone but not forgotten; 2011 Golf GTD; 5dr Carbon Grey, Grey Jacara tartan seats, 18" VW Rotary alloys in Anthracite, Bi-xenons, Parking Sensors, RCD510+Dynaudio, Luxury Pack.
Offline Jim_mk7.5
« Reply #27 on: 08 February 2019, 14:10 »
Yes, should have mentioned drying as well. If anyone is still using a Chamois leather - please immediately go and put it in the bin!
Offline Yusee
« Reply #28 on: 08 February 2019, 14:32 »
Using microfibre towel. Just picking up some turtle wax snow foam now!
Offline Cardy
« Reply #29 on: 08 February 2019, 19:44 »
Sounds a great choice look forward to seeing some pics mate
