Author Topic: Drive shaft oil seal  (Read 5930 times)
Offline alexisb
« on: 16 September 2018, 11:57 »
Hi
It leaking a little oil behind the driveshaft flange :(
It's on the left side, behind the short driveshaft flange where it goes into the gearbox.
1996 VW GOLF VAR CL 1,8I ADZ MAN CHB 66kw is the car
Could this be the right seal ? CHB is the gearbox for ADZ/96
020 311 113   21,9X40X8 mm    CHB,CHD,CJF,DFP,DFN,DGG
Regards
Alexis
Offline gazareth
Re: Drive shaft oil seal
« Reply #1 on: 02 November 2018, 18:16 »
just had a look on ecp website as I need one too. yes that would appear to be the right dimensions :smiley:
Offline gazareth
« Reply #2 on: 11 November 2018, 18:38 »
sorry that's not the one :huh: for some reason,i was thinking about the mainshaft oil seal inside the clutch housing. hope someone else put you right :wink:
Offline alexisb
« Reply #3 on: 30 November 2018, 07:24 »
Hi
I found the right seals :)
Now its only time thats missing ...
Regards
Alexis
Bokföring och Lön för Mac http://www.ct.se/
