Author Topic: Mk3 Golf Gti wont start !  (Read 4242 times)
Offline Modmucka89
« on: 18 August 2018, 12:03 »
Help ! I've got a 1992 K GTI 2.0l 8v been sat a while but ran fine before. I have compression, decent spark and have replaced what I expected to be a dodgy fuel pump and it still won't go. I've checked all the fuses and the fuel pump relay, all of which are fine. There is no resistance running through the relay and there is power to the pump. It doesn't have a crank sensor, I've had the front mount off and looked ! I even replaced the knock sensor just incase. I'm out of ideas now and beyond cheesed off ! Anyone had the same issue that can help me out ???
Offline WeekendMechanic
  • Golf MK3 GTD
Re: Mk3 Golf Gti wont start !
« Reply #1 on: 23 August 2018, 17:34 »
Does the engine turn?
If so its a timing issue if not try cheeking the starter brushes.
Offline gazareth
« Reply #2 on: 01 September 2018, 10:43 »
can you hear the fuel pump running? if so, is there fuel getting to the injector rail?
