Author Topic: Old boy needs some help  (Read 1189 times)
Offline turbokid23
« on: 22 June 2018, 17:58 »
Hi guys need a bit of help my gti has decided to go mental it drive fine but on boost id decides to go into limp mode and enginmanagnent light flashes but tryed evry think and cant seem to find the problem any ideas would be aprecated thanks
Offline sharki786
  • GOT BOOST??
Re: Old boy needs some help
« Reply #1 on: 22 June 2018, 18:40 »
1st thing i would do is check for error codes with a diadnostic machine. Also check vac lines and the hoses and check for splits.
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline turbokid23
« Reply #2 on: 22 June 2018, 20:53 »
Done all that pal no codes and no cracks or leaks im going to change the plugs tomorrow see if that makes any diffrance
Offline brettblade
« Reply #3 on: 25 June 2018, 09:56 »
Could very well be map related.
Orded 04/06/2016
Build W/C 01/08/2016
Handover 01/09/2016
GTI PP, CSG, Tech pack, parking pack, 90% tints, DCC, 19" Santiago alloys
Soon to be gone!
7.5R Indium Grey, 19” Spielbergs expected 01/03/2019.
Offline Dalo Harkin
« Reply #4 on: 04 July 2018, 12:50 »
It wont be plugs if its when it boosts. You need to look at things that actually control the boost so N75, Turbo actuator etc
