Author Topic: Sawtooth  (Read 5479 times)
Offline cyclopops
Sawtooth
« on: 29 July 2017, 19:55 »
Does anyone else's tyres suffer from this?
https://www.oponeo.co.uk/tyre-article/saw-tooth-tyre-wear
I have the original bridgestones on, so was wondering if it's a common thing on other brands too?
Offline SRGTD
Re: Sawtooth
« Reply #1 on: 29 July 2017, 20:13 »
Had it on my mk5 Golf. Became very noisy and sounded as if a rear wheel bearing had failed. You could see and feel the 'stepped' tread on the inside edge of the rear tyres. Tyres were Bridgestones.
Haven't experienced it on subsequent cars.
Gone but not forgotten;
2016 Polo GTI; Blue Silk
Offline mcmaddy
Re: Sawtooth
« Reply #2 on: 29 July 2017, 22:42 »
It happened on mk5 golfs due to wear in the rear suspension.
Offline cyclopops
Re: Sawtooth
« Reply #3 on: 29 July 2017, 23:46 »
This keeps happening on my fronts only.
Offline Watts
Re: Sawtooth
« Reply #4 on: 29 July 2017, 23:58 »
Thought I had it on the back but it was a dodgy wheel bearing. I rotate my wheels to keep the wear even, I think that helps.
2019 Oryx White 5dr TCR.
Was - 2015 Tornado Red 3dr GTI PP, manual, Santiagos, Audi short shifter.
Offline fredgroves
Re: Sawtooth
« Reply #5 on: 30 July 2017, 12:32 »
With a few mm left and after ~60k my original rear OEM BS's finally drove me mad with this.
I can't complain really, ~60k is incredible really.
Offline itavaltalainen
Re: Sawtooth
« Reply #6 on: 30 July 2017, 12:49 »
My P7s did it as well.
Now I swap fronts and backs diagonally every so many miles. Also wears them out evenly, so some hope the lease company then put on four of the same (well once they didn't).
Offline Watts
Re: Sawtooth
« Reply #7 on: 30 July 2017, 12:53 »
That is, my P-Zeros are close on 18k and I think they would do 20 but I want to change them before winter regardless. They had a hard life for the first 1500 miles as a demo car judging by the test drive I had....
Offline monsta
Re: Sawtooth
« Reply #8 on: 13 August 2017, 18:46 »
This is what drives me a little mad about golfs! My mk5 did it, my mk7 does it... What's the solution?
Offline I wanted a GTi
Re: Sawtooth
« Reply #9 on: 13 August 2017, 19:46 »
Tracking, not the VW tracking figures. Had it done on my CC's to stop it and never had a problem again, plus point was a nice little bit of lift off oversteer when i wanted a bit of fun. You will need to find someone that knows how to do it though, I have mine done in Birmingham.
