Author Topic: mk7 gti wheel corrosion  (Read 6982 times)
Offline Nacco34
« on: 22 June 2017, 21:11 »
Has anyone every have a warranty claim on corroding wheels
I have noticed all 4 of my wheels have started bubbling in the exact same place near the air valve.
Just wondering if I would get any joy from VW or what i can do about it as the car is 3 and half years old only 19,000 miles. Also when purchased had the extended warranty which ends in November
Any info will be greatly appreciated
Thanks
Offline brettblade
Re: mk7 gti wheel corrosion
« Reply #1 on: 23 June 2017, 08:58 »
It's worth chasing up with a couple of dealers in your area, but they'll likely say it's due to damage caused by tyre fitters (and in reality, in probably is if you've got similar damage on all 4 wheels in the same place).
Orded 04/06/2016
Build W/C 01/08/2016
Handover 01/09/2016
GTI PP, CSG, Tech pack, parking pack, 90% tints, DCC, 19" Santiago alloys
Soon to be gone!
7.5R Indium Grey, 19” Spielbergs expected 01/03/2019.
Offline SRGTD
« Reply #2 on: 23 June 2017, 18:25 »
When I owned my mk6 Golf GTD, I had 2 wheels replaced under the 3 year factory warranty. They were diamond cut alloys that had suffered from whiteworm corrosion due to a manufacturing defect.
Whether or not you may be successful getting a claim submitted under warranty will depend on which extended warranty you have;
1).  if you bought the car used and it had VW's Das Welt Auto used car warranty, this only covers electrical and mechanical failures, so wheels wouldn't be covered.
2). if the car's warranty was extended at the end of the original 3 year factory warranty by the purchase of a VW Extended Warranty, this also is a warranty covering electrical and mechanical failure, so wouldn't cover wheels.
3). if you have the benefit of the Extended Factory Warranty, this may cover the wheels as it should give exactly the same warranty cover as the original 3 year warranty that came with the car, but had to have been purchased when the car was originally ordered / bought new. If your extended warranty was purchased at a later date, you won't have the benefit of the Extended Factory Warranty - you'll have an electrical and mechanical failure warranty that wouldn't cover the wheel damage you're experiencing.
If you have number 3). above, it's worth going to your dealer and trying to claim for new wheels. At 19,000 you may still have the original tyres on the car, in which case the bubbling around the tyre valves is likely to be due to a manufacturing defect rather than tyre fitter damage.
If based on the above, you conclude you don't have warranty cover for your wheels (or if VW say 'no' to your claim), then you could consider getting your wheels refurbished. One wheel refurbishment company that pretty much always gets very good reviews on this (and other) forums is Lepsons (www.lepsons.com). They're based in Gilligham, but if they're not local to you they often offer a free courier service.
Good luck!
« Last Edit: 23 June 2017, 19:55 by SRGTD »
Gone but not forgotten;
2016 Polo GTI; Blue Silk
