Author Topic: Windows don't work  (Read 1460 times)
Offline Gary#turbo
  • 100%boostaddict http://www.golfgtiforum.co.uk/inde
Windows don't work
« on: 06 January 2017, 16:42 »
i've got a mk4 golf 1.8T 6 speed . I had my clocks changed to the immo3 version and then after that my windows / mirrors dont work central locking has never worked either , Ive changed fuse 14 and also the 15amp fuses in the ccm unit and still nothing if i dissconnect the battery they work after about 5minutes ive ran out of ideas on what can cause this to happen they only want to work when they want to !! What else can i check its not like they dont work but maybe a loose connection ?
Anyone on here that can help ?
Offline itavaltalainen
Re: Windows don't work
« Reply #1 on: 06 January 2017, 17:33 »
Ccm faulty perhaps?
Maybe missing can signals?
I would check fault codes in all control modules. Could assist you with that, where are you based?
Offline Gary#turbo
« Reply #2 on: 10 January 2017, 15:15 »
I dont no now i've ran out of ideas , Your help would be much appreciated , im based just off jct 2 from the M5 , Were are u ?
Thanks
« Reply #3 on: 10 January 2017, 15:22 »
Am near j7 (worcester) when not away for work. Might be in Birmingham for for a job next week.
If you're able to come down to Malvern on Thursday or Friday I should be home.
Offline Gary#turbo
« Reply #4 on: 10 January 2017, 15:44 »
ill pm you  :smiley:
« Reply #5 on: 17 January 2017, 18:20 »
Friday,13,January,2017,15:54:34:14667
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 16.8.4.2 (x64)
Data version: 20161129 DS267.0
www.Ross-Tech.com
VIN: WVWZZZ1JZ3W18xxxx   License Plate:
Mileage: 180570km-112200mi   Repair Order:
Chassis Type: 1J (1J - VW Golf/Bora IV (1998 > 2006))
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
          76
VIN: WVWZZZ1JZ3W18xxxx   Mileage: 180570km-112200miles
Address 01: Engine        Labels: 06A-906-032-AJQ.lbl
   Part No: 06A 906 032 HN
   Component: 1.8L R4/5VT         0002
   Coding: 11510
   Shop #: WSC 01271
   VCID: 71E9D1723B9051CA36-xxxx
   WVWZZZ1JZ3W18xxxx     VWZ7Z0B577xxxx
6 Faults Found:
16804 - Catalyst System; Bank 1
            P0420 - 35-00 - Efficiency Below Threshold
17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
            P1297 - 35-10 -  - Intermittent
17608 - Boost Pressure Control Valve (N249)
            P1200 - 35-00 - Mechanical Malfunction
16946 - System Voltage
            P0562 - 35-10 - Too Low - Intermittent
18010 - Power Supply Terminal 30
            P1602 - 35-10 - Voltage too Low - Intermittent
16706 - Engine Speed Sensor (G28)
            P0322 - 35-10 - No Signal - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes        Labels: 1C0-907-37x-ASR.lbl
   Part No: 1C0 907 379 K
   Component: ASR FRONT MK60      0103
   Coding: 0021505
   Shop #: WSC 01271 785 00200
   VCID: 326B1E7EAE162AD20F-xxxx
1 Fault Found:
00290 - ABS Wheel Speed Sensor; Rear Left (G46)
            012 - Electrical Fault in Circuit - Intermittent
Address 08: Auto HVAC        Labels: 3Bx-907-044.lbl
   Part No: 3B1 907 044 C
   Component: CLIMATRONIC     C 2.0.0
   Coding: 11000
   Shop #: WSC 01271
   VCID: 2149E132ABF0A14AE6-xxxx
1 Fault Found:
01274 - Air Flow Flap Positioning Motor (V71)
            37-10 - Faulty - Intermittent
Address 15: Airbags        Labels: 6Q0-909-605-VW5.lbl
   Part No: 1C0 909 605 A
   Component: 27 AIRBAG VW51 01   0004
   Coding: 12855
   Shop #: WSC 01271
   VCID: 224BEE3EAEF6BA52FF-xxxx
1 Fault Found:
00532 - Supply Voltage B+
            07-10 - Signal too Low - Intermittent
Address 17: Instruments        Labels: 1J0-920-xx5-17.lbl
   Part No: 1J5 920 926 A
   Component: KOMBI+WEGFAHRSP VDO V13
   Coding: 05412
   Shop #: WSC 12345
   VCID: 2D510D02E728752A52-5106
No fault code found.
Address 19: CAN Gateway        Labels: 6N0-909-901-19.lbl
   Part No: 6N0 909 901
   Component: Gateway K<->CAN    0001
   Coding: 00006
   Shop #: WSC 12345
   VCID: 70EFD476309A58C239-xxxx
Address 46: Central Conv.        Labels: 1C0-959-799.lbl
   Part No: 1C0 959 799 B
   Component: 1Y Komfortgerát HLO 0003
   Coding: 00065
   Shop #: WSC 00808
   VCID: 3663226E127E36F223-xxxx
   Subsystem 1 - Part No: 1C2959802A
   Component: 1Y Tõrsteuer.FS KLO 0004
   Subsystem 2 - Part No: 1C2959801A
   Component: 1Y Tõrsteuer.BF KLO 0004
4 Faults Found:
01299 - Diagnostic Interface for Data Bus (J533)
            49-10 - No Communications - Intermittent
00956 - Key 2
            09-00 - Adaptation Limit Surpassed
01330 - Central Control Module for Central Convenience (J393)
            37-00 - Faulty
00928 - Locking Module for Central Locking; Front Driver Side (F220)
            27-00 - Implausible Signal
End-------------------------(Elapsed Time: 04:59)--------------------------
Offline topher
  • Administrator
  • fully functioning
« Reply #6 on: 22 January 2017, 18:12 »
check the door harness wiring between the a-pillar and the door
« Reply #7 on: 23 January 2017, 16:20 »
We did, that looked OK.
CCM is dead, resoldered the joints but there major fault on board - just posted error log for OP to have reference which P/N and colour code to buy.
