Author Topic: AUM 1.8T What setup have i got?  (Read 4561 times)
Offline Rg_
Re: AUM 1.8T What setup have i got?
« Reply #20 on: 04 January 2017, 18:02 »
Oh I got confused by "spaghetti " pipe as the small one that goes into the top of the nipple of the dump valve.  Makes sense now.
I'm happy where everything needs to go now apart from just need to see a pic of where that small one goes from the nipple to the inlet manifold. I should be able to reuse that thin hose that is on the nipple of my current dump valve at the moment.
I've ordered the 008 and 3m of silicone hosing. In case I need spare etc.
I need to get that OEM pipe that goes into the blank charge pipe to the side of the DV.
Offline Nino
« Reply #21 on: 04 January 2017, 21:24 »
These are pictures of my old bay, might help you with locations etc,
VW Car history
Mk3 1.8 GL - Silver - 5 door
Mk4 1.8t - Silver - 3 door
Mk4 R32 - Black - 5 door
Mk5 GTi - Black - 5 door
Mk4 R32 - Deep Pearl Blue - 3 door
MK6 2.0 TDI - Graphite Blue - 5 door
MK7 GTD - Solid Black - 5 door
MK6 GTi Edition 35 - Candy White - 3 door
Offline Rg_
« Reply #22 on: 04 January 2017, 22:44 »
Very nice mate! Those silver braided hoses you have on the left side near the coolant. I was looking at black braided  ones on eBay to replace those pipes but wasn't sure what size they are?
Been looking at induction kits. Saw the ram air one. I've got a pipercross panel filter at the moment.
Offline Nino
« Reply #23 on: 04 January 2017, 23:02 »
I had that RAM custom made, wasn't checp but was assured it wouldn't heat soak but I am not convinced it didn't tbh.
I cannot remmeber the size on the braided lines sorry pal, I bought them 2nd hand.
VW Car history
Offline Rg_
« Reply #24 on: 04 January 2017, 23:25 »
Yeah was gonna say it looks different to the ones for sale.
Oh no worries, ill have to measure.
Offline lemski
  • 16v
« Reply #25 on: 05 January 2017, 07:52 »
Under neath the inlet on the opposite side to the throttle body youll feel where two vac lines go. One of the should go to youve dumpvalve
Offline Rg_
« Reply #26 on: 05 January 2017, 08:34 »
Thanks!
Offline Rg_
« Reply #27 on: 05 January 2017, 14:14 »
One last thing so i can ask TSP for the pipe, whats the name of the pipe that usually goes from here to the recirc valve 008. 008 has arrived but cant fit without that pipe!
IMG_1263 by Richard Gaona, on Flickr
Offline lemski
  • 16v
« Reply #28 on: 05 January 2017, 15:12 »
Ricerc pipe to turbo outlet should get you the correct one
Offline Rg_
« Reply #29 on: 05 January 2017, 19:10 »
Whizzed down my local breakers and grabbed one.
008 all fitted now with into the OEM position. Also found out i had a tear in the small blue 3mm vaccum hose so sorted that too. I thought i had heard a faint hissing.
Going to take the car for a spin and see how it feels.
Thanks for the help guys. Next i will do the N249 bypass and been looking at the SAI delete but heard mixed things about that one...
