Author Topic: Amp always on  (Read 4051 times)
Offline hardmonkeys
Amp always on
« on: 02 October 2016, 17:23 »
Just fitted a amp into the convertible and now the amp is always on,
I also fitted a new head unit, a Sony DSX-A400BT, I put the blue wire from the wiring kit to the REM IN on the amp, and to the blue wire on the back of the HU, when I turn the radio off, the amp doesn't turn off, even if I remove the wiring harness from the back of the HU, the amp is still powered...any ideas?
'05 VW Golf Mk V GT TDI Laser Blue
'98 VW Golf Mk IV GTi Black
'97 VW Golf Mk III GTi
'58 VW Golf Mk V GT Sport TDI Steel Grey
'10 Audi A4 B8 SE Multitronic
'00 VW Golf Mk III.V Cabrio
MK3.5 Cabrio 2.0 8v Automatic to 2.0 16v Manual Conversion Project
http://www.golfgtiforum.co.uk/index.php?topic=272728.
www.dorsetautorestore.co.uk
Offline lemski
  • 16v
Re: Amp always on
« Reply #1 on: 02 October 2016, 18:31 »
Put a switch into the live cable. Obvously if the remote switch isnt doing what it shoild.
Or try the old headunit incase the red/yellow are different and its keeping live on
Offline hardmonkeys
Re: Amp always on
« Reply #2 on: 02 October 2016, 22:59 »
Nice one!
Will try this tomorrow now. The amount of amps I've fitted, for myself and others, I've never come across this problem..
Offline lemski
  • 16v
Re: Amp always on
« Reply #3 on: 03 October 2016, 08:13 »
I havnt either but if the red and yellow are wrong normally the cd player wont have memory. But dependant on how the wiring in you dash is it could be sending perminant live to the blue.
Also check that when youve put the live on the amp, non of the wires are touching the remote. Just a thought
Offline hardmonkeys
Re: Amp always on
« Reply #4 on: 03 October 2016, 17:14 »
Sorted it!
Traced the remote wire back to the VW plug and it had a red/wire, not sure what it was for but it was providing a permanent live to the amp, so...I cut it lol and now no permanent feed to amp!
https://imgur.com/gallery/jXCg6
The HU now provides the amp with power when it's on and turns off the HU is off. Had a memory problem too, but that's sorted now.
Thanks Lemski for your help
Offline lemski
  • 16v
Re: Amp always on
« Reply #5 on: 03 October 2016, 18:29 »
Always a pleasure. The red wire is live feed.to head unit. Normally yellow.and red are switchable to make Hu have memory
