Author Topic: Things to try on 2.0 8v wen cuttin out seems to be a big issue  (Read 1939 times)
Offline Y I GTI
ecu relay number 30
fuel pump relay number 80
if relays are cold wen car is warm change them.
Ignition coil common on these
Throttle body cleaning, remove black pipe between airflow meter n housing,remove thin vacum pipe from top of housing.remove accelerator cable,remove 4 allen key bolts round housing,loosen bottom pipe wen housing loose,remove electric plug,on housing, clean housing wiv carb cleaner or brake cleaner.
distribuator cap
rotar arm
Plug leads n  plugs
distribuator,hall sensor
oil pressure sensor
clean throttle control valve
Reset ecu, disconnect battery for about 15 mins n reconnect
Crank sensor, situated jus above oil fliter housing black sensor,wiv wire that runs behind housing
Ignition switch
Battery earths under battery tray
Temperature sensor
air flow meter
Vacum pipes prone to leaks
Problems had wiv mine are that car wud start perfect,get warm to about 78c n cut out if left for few mins wud start straight away, if tried to start after it cut out wud sound like it was starving ov fuel or misfiring badly n cut out,cuts out under load wen accelerating or jus drivin normally no matter what revs car will lose power n die,somedays car will run fine.somedays tho wud feel like was hesitating wen tryin to boot it or wud feel like it is holding back.tried most ov things ave mentioned gonna change coil,n crank sensor next few days see what happens.
