Author Topic: Archie's A4 Wagon  (Read 22265 times)
Offline archie837
Archie's A4 Wagon
« on: 12 June 2016, 10:24 »
So after a couple of years of rolling about in a mk4 anni and fixing everything with it, I came into some money and thought it was time to get something a bit newer with some carrying capacity.
It's a 2008 3.0 TDI V6 and is probably the nicest thing I've ever owned.
The guy I bought it from has looked after it fairly well and serviced it every 10k, valeted every week etc. he also specced it up with the bang and olufsen 14 speaker system which is ace.
When we picked it up he also said he'd had it mapped which was nice as it was the first thing I was going to do.
There are a few things it needs - he ran this on crap budget tyres. I've replaced the rears with some rainsports which has made a massive difference, but has highlighted the alignment is cock as it gets a right wander on at speed. Also changing the rears has highlighted the fronts are bad and really noisy.
Really happy with it at the moment, just need to sort these little bits now
Project longterm Airbanger.
PD150 Anni daily
Offline Rhyso
Re: Archie's A4 Wagon
« Reply #1 on: 12 June 2016, 10:36 »
Welcome to Club Wagon   :grin: :cool:
Offline JC
  • Back in the North.
« Reply #2 on: 12 June 2016, 20:34 »
 :cool:  but Enough with the Wagons ............................
Offline archie837
« Reply #3 on: 13 June 2016, 11:00 »
I'm basically being rhyso
Blowing up pd150's and then moving across marques
PD150 Anni daily
Offline Rhyso
« Reply #4 on: 13 June 2016, 12:00 »
Oi!!!
Mine was a 130, not a 150!  :tongue: :laugh: :laugh:
Offline archie837
« Reply #5 on: 13 June 2016, 13:44 »
 :grin: :grin: :grin: :grin:
PD150 Anni daily
Offline lemski
  • 16v
« Reply #6 on: 18 June 2016, 15:11 »
My mates got one of these, excellent drive. Much more refined to my b5.
Wagons the only way
Offline archie837
« Reply #7 on: 22 August 2016, 18:31 »
Quick update on this.
I changed the rear tyres and fitted some rainsports to it. Big mistake as the car now wanders badly at high speed. Did have the alignment done so it is straight. General consensus is the tread pattern is causing it to grab on each side which the 4wd doesn't like. Will try some Audi marked dunlops and see what happens.
Did a trip to Wales and this was perfect for it. Loaded it up with 2 dogs in the back and off we went. Set the cruis to 80 with a couple of higher / lower patches of speed and averaged 44mpg. Plus got out the other end without feeling sore or stiff - it is absolutely brilliant at mile munching and the bigger engine is just so effortless.
I also changed out the air and pollen filters as they were filthy and had the air con done too.
Next thing to fit is the LED bulb kit I got as I can't stand the pissy yellow colour of the interior lights.
So hopefully a set of new tyres should cure the wandering and give me back the mega planted feel I had before.
PD150 Anni daily
Offline Rhyso
« Reply #8 on: 22 August 2016, 18:55 »
Weird how thats affected the handling
I got RainSports all round on the A6 and it grips and goes without issue  :undecided:
What have you got on the front?
I had an issue with Goodyears on the front and RainSports on the back of my A3; going around corners the TC would in and brake the inside front wheel
Offline archie837
« Reply #9 on: 23 August 2016, 17:09 »
it is a different read pattern on on the front so I think it is a case of the rear is gripping more than the front.
I don't know whether to try rainsports on the front as well and see if it smooths it all out by having a matching set?
It's the backend it really wants to let loose - had some scary moments after coming off roundabouts at speed.
PD150 Anni daily
