Author Topic: R Footwell Lights - replacing standard white LEDs with blue LEDs  (Read 21876 times)
Offline Booth11
I mentioned in my initial review of my R, that I found the interior a bit lacking in colour.  Well today I have rectified that a little.
Swapped the white footwell standard LED lights for some blue ones.
The standard white LED light units are unfortunately sealed so in order to fit blue LEDs you'll need to replace the whole thing, you can't just swap the bulbs over like you could on the Mk6.  You'll need to order 2 standard Mk7 Glovebox light housings that come with tungsten bulbs fitted.
Available from Trade Parts Specialists (TPS) https://www.thetradepartsspecialists.co.uk or order via your VW dealer - Part no. 7L0 947 415 @ £11 each (inc VAT).  Blue LED bulbs from eBay http://www.ebay.co.uk/itm/4-x-ERROR-FREE-CANBUS-5-SMD-CAR-LED-BLUE-W5W-T10-501-SIDE-LIGHT-BULBS-BLUE-/320865983677. Thanks very muchly to JB GTI on here for that info. :smiley:
Installation:
First off, remove the existing light housings.  You need a small flathead screwdriver or small trim tool for this.  There is a small slot at the accessible end of the light, gently push in here and gently pry one end of the light out of it’s recess, ease the other end out.  Squeeze the connector to unplug and release the light unit.  Set the lights aside.
Onto the replacement light units. You need to remove the metal casing to be able to access the tungsten bulb within, use the small flathead screwdriver to pry off the metal casing.  You need to get the head of the screwdriver just under each of the 4 corners and slightly bend the sides out on either side, then you can slide the casing off.  Remove the existing tungsten bulb and replace with the blue LED (sourced from ebay).  You may have to push the bulb in quite forcefully or ease the metal holder just a little to accommodate it.
As with this type of LED you need to check you have the polarity correct BEFORE reattaching the metal casing and closing up the light unit again, so try it connected up and if the bulb doesn’t work one way, turn it around and try the other way.  Once the LED is in the correct way, and working, replace the metal casing by sliding back into position and pressing any bent ends flat again.  Now plug the whole unit into the connector and gently ease the light back into position in it's hole.  Voila!
The driver’s side is very easy to do, a 2 minute job. The electrical wire on the driver’s side is quite long so easy to access. The passenger side, however is more tricky.  The wire is extremely short and the connector sits just inside the hole, but there is no scope at all to pull it further out. It’s fine getting the original light unit out but getting the replacement unit back into the connector is very fiddly and needs two arms and hands. Helps if you have slim fingers, but if you have chunky digits, you may struggle. You can always remove additional trim (I didn't). And because it’s so tricky, I strongly recommend testing the passenger LED out on the driver’s side first BEFORE putting it in the passenger side.
Once all done, you can, via the car menu, in Lights, set a % brightness for the footwells.  I set mine to 80%.
Installation pictures:
Remove standard white light LED unit
Fit Replacement light unit and blue LED
The result (with footwells set to 80%)
Blue LED footwells at night  Look great with the blue door strips.
Driver’s side
Passenger side
The standard white light is quite cold and harsh.  The blue really adds to the ambience and injects adds a bit of much needed colour.  :cool:
« Last Edit: 19 October 2015, 23:31 by Booth11 »
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline mcmaddy
Where did you get your blue bulb from Booth?
Offline Booth11
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline mcmaddy
Thanks Rebecca.
Offline titchy
I wonder if it'd be possible to create the same, or similar result by using a coloured film or gel as often used in photography, if one couldn't be bothered to pay £20+ on new led's and surrounds?
Black, 3 Door, MY '16 GTI.
Dynaudio, AppConnect.
Offline hog_hedge
Thanks for the guide Booth, I now have red LED footwell lights in my GTI :cool:
Offline 7MAT
Hi
Any chance of posting a pic of the red footwell lights please?
Regards
Matt
MK7.5 Golf GTI Performance, 3 door, Issac Blue, DCC, Manual. Racingline Stage 1 OEM+, Remus Exhaust system, Sache Performance Clutch.
Offline Watts
Hi
Regards
Matt
Hi Matt, not the best shot ever but hope this helps:
2019 Oryx White 5dr TCR.
Was - 2015 Tornado Red 3dr GTI PP, manual, Santiagos, Audi short shifter.
Offline 7MAT
Hi
Regards
Matt
Yeah I like that, thanks for posting!
Offline danpen1306
Re: R Footwell Lights - replacing standard white LEDs with blue LEDs
« Reply #9 on: 04 September 2017, 15:54 »
Do you have a link to these? I've checked the seller of the blue ones on ebay but he doesn't seem to stock red ones
New - 2019 Golf R, Indium Grey, 5 door, Black gloss Pret's, Dynaudio
Gone - 2018 Audi S3 Saloon, Ara Blue, 19" V spokes, Tech pack
Gone - 2016 GTI PP, Black, 5 door, DSG, CarPlay
Gone - 2012 GTD, Candy White, 5 door, Charleston's, DSG, Leather, RNS-510, Bluetooth, Parking Sensors and a Big Smile
