Author Topic: Vagcom Diagnostic scan on my 02' Golf MK4 GTI 8V. Faults galore..  (Read 10925 times)
Robracer
Hi, I've just scanned my 02' Golf GTi MK4 8V with Vagcom and the below results appeared.
I'm used to wealeding a spanner and a laptop so I'm willing to get my hands dirty to fix all the faults.
I still own a MK3 golf GTI 8v too! (slowly becoming Rusty f**ker)
Anyway what I'm concerned with is, what will be likely to fail an MOT?
Plus she's been sat for a few month's.
Cheers :)
Address 01: Engine        Labels: Redir Fail!
   Part No: 06A 906 032 FK
   Component: 2.0l 2V AGW         4094
   Coding: 00001
   Shop #: WSC 00046
   VCID: 6CD7223B1C7E2C7E58B-5072
   WVW**************     VW****************
2 Faults Found:
16955 - Brake Switch (F)
            P0571 - 35-10 - Implausible Signal - Intermittent
16804 - Catalyst System; Bank 1
            P0420 - 35-10 - Efficiency Below Threshold - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes        Labels: 1C0-907-37x-ABS.lbl
   Part No: 1C0 907 379 J
   Component: ABS FRONT MK60      0103
   Coding: 0001025
   Shop #: WSC 00046 615 1234567
   VCID: 3169F34FABDC81962BD-5072
No fault code found.
Address 08: Auto HVAC        Labels: 3Bx-907-044.lbl
   Part No: 3B1 907 044 C
   Component: CLIMATRONIC     C 2.0.0
   Coding: 11000
   Shop #: WSC 00046
   VCID: 2149030FAB3C3116BBD-5072
1 Fault Found:
01274 - Air Flow Flap Positioning Motor (V71)
            37-00 - Faulty
Address 15: Airbags        Labels: 6Q0-909-605-VW5.lbl
   Part No: 1C0 909 605 A
   Component: 27 AIRBAG VW51 01   0004
   Coding: 12855
   Shop #: WSC 00046
   VCID: 224B0C03AE3A2A0EA27-5072
1 Fault Found:
00532 - Supply Voltage B+
            07-10 - Signal too Low - Intermittent
Address 17: Instruments        Labels: 1J0-920-xx5-17.lbl
   Part No: 1J0 920 926 A
   Component: KOMBI+WEGFAHRS. RB8 V17
   Coding: 05412
   Shop #: WSC 00050
   VCID: 285F1E2BC806C05EFC3-5000
   WVW****************     VW****************
Address 19: CAN Gateway        Labels: 6N0-909-901-19.lbl
   Part No: 6N0 909 901
   Component: Gateway K<->CAN    0001
   Coding: 00006
   Shop #: WSC 00046
   VCID: F0EFB64BB056489EE43-5072
Address 46: Central Conv.        Labels: 1C0-959-799.lbl
   Part No: 1C0 959 799 B
   Component: 1Y Komfortgerát HLO 0003
   Coding: 00064
   Shop #: WSC 00046
   VCID: 3663C05312B2A6AE7EF-4A9C
   Subsystem 1 - Part No: 1C2959802A
   Component: 1Y Tõrsteuer.FS KLO 0004
   Subsystem 2 - Part No: 1C2959801A
   Component: 1Y Tõrsteuer.BF KLO 0004
5 Faults Found:
01330 - Central Control Module for Central Convenience (J393)
            52-10 - Supply Voltage Too High - Intermittent
            53-10 - Supply Voltage Too Low - Intermittent
            37-00 - Faulty
00928 - Locking Module for Central Locking; Front Driver Side (F220)
            27-10 - Implausible Signal - Intermittent
01332 - Door Control Module; Passenger Side (J387)
Address 56: Radio        Labels: 1J0-035-18x-56.lbl
   Part No: 1J0 035 186 D
   Component:  RADIO SON         0004
   Coding: 01403
   Shop #: WSC 00046
   VCID: 26431013C212D62ECEF-49D8
1 Fault Found:
00668 - Supply Voltage Terminal 30
End   ---------------------------------------------------------------------
Offline Rhyso
Brake switch is most likely as your brake lights might not be working; located under the brake pedal and about £15 from the dealers
Have you cleared the codes, driven it and then seen what's come back??
Most of those are simply low battery faults which if its been sat a while are not surprising
Clear the codes, drive it and then re-scan; that could save you a lot of money as I suspect most won't reappear
Offline itavaltalainen
Brake switch is clear.
Cat not being efficient could be one of the two sensors, or cat is failing.
Intermittent supply voltage can normally be cleared but may be indicator that your battery is on way out.
The implausible signal on front driver side lock is a faulty micro switch in lock, you need to take lock out, remove old microswitch, solder wires to a new switch then align and glue it in. Can post part number for micro switch if you need. (switch is 4£ - new lock is 40£ - 2nd hand lock may have same issue so I'd recommend to get switch not a lock :D )
Seat Leon ST FR DSG on order :)
Robracer
Thanks for the reply's, I managed to get under the car today for a few hours  :smiley: I gave it a oil change inc filter, checked the spark plugs, they need replacing, cleared all the codes, the battery terminals were also loose for some reason, then gave the car a short drive on private land i must add. So far, not a single code has re-appeared. So I can book it in for an MOT next week and hope the cat fault doesn't appear again? And realised the rear wiper jet is blocked! I have more to do it seems.. Oh and the brake lights work as they should, that code was a ghost i reckon?
Rob
« Last Edit: 20 June 2015, 09:12 by Robracer »
Robracer
Hi, Today I thought i'd scan the ecu with vagcom to see what code if any might re-appear?
Nothing of any importance, such as the cat etc..
But vagcom did tell mee this:
But the main diagnstic isn't telling me anything like it did before?
Also the exhaust now smokes white under acceleration when upto correct temp!
Any idea's???
Cheer's :)
« Last Edit: 20 June 2015, 18:16 by Robracer »
