Author Topic: air con clutch  (Read 1904 times)
Offline crazydog
air con clutch
« on: 23 May 2015, 17:44 »
 hi guys,i've finally got my aircon working cold,my query is does the pulley clutch stay engaged whenever the engine is running regardless of which temp the climatic control is set on.the clutch is engaged now as soon as i start up.     cheers any help welcome
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: air con clutch
« Reply #1 on: 25 May 2015, 12:09 »
I'm no expert on climatic but I'd say yes as it will always be trying to reach the goal temp.
Turn the climatic off completely and see if the clutch is still engaged. You can also do this via VAG COM in the engine measuring blocks, it's something like 023. It will give you a an AC on/off state
