The garage
Diagnostics - VagCom / VCDS
Rhyso
Vag Com - AGU not connecting - what setting??
Topic: Vag Com - AGU not connecting - what setting?? (Read 8090 times)
Ajay
14 May 2015, 16:58 »
I tried to Vag Com the car and it wouldnt respond - the ECU is 06A 906 018 R
Does anyone know what setting I should be using?
Al
WadGTI
Here all the time
Golf GTI'er
Re: Vag Com - AGU not connecting - what setting??
15 May 2015, 13:52 »
Did you test all 4 ports via the vagcom settings?
I would check that you have the port set up correctly and the right driver installed on the pc.
Ajay
15 May 2015, 17:58 »
Didnt test all 4 as the software said interface not found on the other ports in the settings menu.. shall I just try and set it and see what happens?
itavaltalainen
VCDS and VCP - fault codes, coding, VIM activation
20 May 2015, 19:58 »
Which version of VAGCOM or VCDS are you using?
What cable are you using? What port does windows assign the serial port enumerator?
The garage
Rhyso
