Author Topic: 00561 Mixture Adjustment Control  (Read 4326 times)
Offline viperjsy
« on: 03 July 2014, 20:07 »
hi I am getting this code 00561 Mixture Adjustment Control what part will it be
Offline viperjsy
Re: 00561 Mixture Adjustment Control
« Reply #1 on: 14 August 2014, 21:04 »
hi I am still getting this code I have cheacked all vac pipes and boost pipes
Offline WadGTI
  • Golf GTI'er
« Reply #2 on: 08 September 2014, 13:31 »
courtesy from ross tech site.
00561 - Mixture Adaptation
00561 - Mixture Adaptation: Adaptation Limit (Add) Exceeded
Possible Symptoms
Engine Jolting
Increased Fuel Consumption
Poor Idling/Jolting
Reduced Boost Pressure
Possible Causes
Mass Air Flow Sensor (G70) faulty
Fuel Pressure too Low
Leaks in Intake Air System and/or Exhaust System
Injector(s) faulty (i.e. coked)
Possible Solutions
Refuel Vehicle
Check Fuel System Pressure
Check Mass Air Flow Sensor (G70)
Check Intake Air System and Exhaust System for Leaks
Check Injection Quantity
Check Injector(s)
Offline WadGTI
  • Golf GTI'er
« Reply #3 on: 08 September 2014, 13:32 »
ld be checking the MAF with vagcom if possible.
Offline viperjsy
« Reply #4 on: 10 September 2014, 02:13 »
I have replaced the maf the car is running smooth but I am still getting the code
Offline itavaltalainen
« Reply #5 on: 12 October 2014, 01:20 »
this:
Possible Causes
Possible Solutions
Refuel Vehicle
Check Injector(s)
09/2016 Golf VII GTD DSG 50k miles
Gone: 11/2013 Golf VII Variant GT 2.0 TDI pacific blue - 123k miles
DASH SWAPS and KEYS LEARNING for most VWs up to MY2005 even if you don't have the PIN - FAULT CODES - ADAPTATIONS -  Windows via remote fob for Golf 4 and other 2000s VAGs -OXON and the whole country
