Golf mk7
Golf mk7 how to guides + info
Jimble
Which Grade of Oil for a Mk 7 GTI?
Topic: Which Grade of Oil for a Mk 7 GTI? (Read 11196 times)
Marcus P
06 March 2014, 13:18 »
Hi, Which is the correct oil for use in the Uk for a Mk 7 GTI? The manual says 5w 30 / 5w 40. I asked a dealer and they said 0w 30 although you can put a maximum of 5w 30 in?
itavaltalainen
VCDS and VCP - fault codes, coding, VIM activation
Re: Which Grade of Oil for a Mk 7 GTI?
06 March 2014, 21:47 »
using longlife intervals only 5w30 with vw spec 504.00 / 507.00
if not longlife then i'd use 0w40 with vw spec 502.00 (teboil diamond plus 0w40, mobil 1 0w40, shell helix ultra 0w40)
Marcus P
07 March 2014, 08:53 »
Thanks for the reply
Talk-torque
09 May 2014, 07:24 »
All cars are delivered set up for long life, so, if your car has not had a service/oil change, it will have the 5W30, 507 spec. oil in the engine. Probably not wise to mix different specs, especially as the engine will still be bedding in.
Roger.
Golf mk7
Jimble
