Author Topic: lowering mk6 2.0 TDI 140 DSG options please!?  (Read 12934 times)
Offline john_cook
« on: 07 February 2014, 15:25 »
Hi guys,
I got this car for my wife, its on 18 inch Vancouvers, looks pretty nice, but it looks like a dune buggy the ride height is so high! :laugh:
I'd like to lower it just a small amount, say 10-15mm, so as not to upset the ride too much, because its our family car.
But I can't find any 10-15mm springs to lower my car.
spoke to awesome GTI who said minimum they can do is 25mm drop.
Is this right? I thought the GTD / GTI were only lowered 10mm from the factory. I'd like that sort of stance.
cheers
john
PS - seen some mk6 GTI springs on the classified section here . anyone know if these would  be suited to my diesel ?
« Last Edit: 07 February 2014, 15:49 by john_cook »
Offline dubber36
Re: lowering mk6 2.0 TDI 140 DSG options please!?
« Reply #1 on: 07 February 2014, 16:04 »
Generally manufacturers quote the drop a spring will give from the standard height. As you have sports suspension you are 15mm lower to begin with, so a 25mm spring should give your a 10mm reduction on where you are at now.
Offline john_cook
« Reply #2 on: 07 February 2014, 16:46 »
sorry, my car isnt the GTD, so its not lowered from the factory
its a 2.0 TDI 140
I would like to lower it a max 10-15mm, but cant find the springs anywhere.
can I fit the GTD springs to it?
Offline Rhyso
« Reply #3 on: 07 February 2014, 18:43 »
-30mm springs will make the car sit 'right'
It is twice the drop you are looking for but you wont have any issues and just think just how much 15mm ACTUALLY is  :grin:
Offline dubber36
« Reply #4 on: 08 February 2014, 22:24 »
I assumed your car was a GT as it had Vancouvers, therefore would have sports suspension. If it is a SE or Match and you want to lower it 15mm, why not fit OEM GT TDI springs.
Offline Booth11
« Reply #5 on: 08 February 2014, 22:30 »
Yes, and it appears a member on here might be selling a standard set of mk6 GT TDI springs. See reply #110
http://www.golfgtiforum.co.uk/index.php?topic=263865.110
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline john_cook
« Reply #6 on: 09 February 2014, 20:05 »
yes, its a 2.0 TDI GT , thats why its got vancouvers. Its not a GTD tho.
its not lowered at all. Its riding really high! Desparately needs dropping
Offline M3 SHAM
« Reply #7 on: 21 February 2014, 13:50 »
This does not sound right.  The GT has a standard 10mm drop compared to SE and Match so it should be a little lower than other models
Offline boneybradley
  • Back in a Mk3...
« Reply #8 on: 21 February 2014, 14:04 »
My lower springs are listed -25mm and as said that's from std suspension ride height. If you want a quote for a set let me know
Offline john_cook
« Reply #9 on: 25 February 2014, 14:01 »
hi mate, what springs have you got for sale?
ideally after a set of OEM mk6 GTD springs which I believe are 15mm lower than the standard mk6.
cheers
