Author Topic: DAB Antenna - OEM Parts - No Aerial On Show! - Done!  (Read 18376 times)
Offline DaveyGTD
« on: 22 January 2014, 15:13 »
Hey folks, I realise that I should have taken pictures, but to be honest, I was more focused on getting the job done and worrying if it would work or not  :grin:
Step 1 - You need to source a DAB Antenna, I bought mine from a seller on eBay here, he was very very helpful so I would recommend buying from him rather than Kufatec;
http://www.ebay.co.uk/itm/281240384275?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
You can if you wanted also buy them from Kufatec here;
http://www.kufatec.de/shop/de/Nachruestset-DAB-/-DAB-Antennenmodul
Step 2 - Open the boot, at the top of the windscreen you need to pull off the trim, this is difficult but use a bit of force as it is clipped in, use trim tools if you have any or brute force may well work! I didn't pull the entire trim off, I just pulled enough to see the antenna and worked on it like that, not ideal, but saves having to re-align the trim once removed fully!
Step 3 - You will see 2 Antennas one on the left and one on the right (as you are looking in at the boot) they are marked with a part code and also have 'L' and 'R' on them.
You need to change the one that has 'L' on it, the part on mine was 5K0.035.552.A To do this, unclip the brown fakra connector, then on the opposite side there will be a bit of black tape, remove this to expose a small black connector cable, gently unclip this also, and you will see a screw holding the antenna in, unscrew this and the antenna should slide out.
Step 4 - Now you will notice on your new antenna it has 2 FAKRA connection inputs, the eBay seller I used, also gives you a double connector adaptor, this is what you need, so if you order from Kufatec you may not get that, so be aware that you need one of those if not.
The brown fakra connector you took off from the original antenna, you need to unclip it from it's housing, simply lift up the purple clip fully with a flat head screwdriver, and the cable will then pull away from it's housing.
You then need to do the same with one side of the new aerial cable that you received in the packaging with the new DAB Antenna, so you are then left with 2 cables without Fakra connectors on, the double connector adapter has '1' and '2' on them, I used the existing cable in '2' and the new DAB cable wiring in '1' (unclip the purple clip from the double connector and slide your existing FM Cable into one hole, and the new DAB cable wire into the other hole) replace the purple clip and they should be snugly inside the double connector - make sure you push them in fully.
Also, remove the FAKRA connector from the other side of the DAB wire (this is the wire that goes into the car) as you need to feed that wire into the car and will have no chance of doing that if the connector is on the end of it!
Step 5 -OK, now, the new antenna had a different mount to the existing, so I actually just used some strong tape to hold it in place while I figure a new solution (if I bother as it works fine as it is) but anyhow, your next step is to feed the wire from the DAB antenna into the car, you will see to the top right of the bootlid a ribbed rubber grommet, pull it out from the top and also pull it out from where it connects into the car, now this is quite a thin grommet inside, so you will be unable to fit the wire inside it without a bit of butchering.
I used a blade to cut open the grommet and slide the wire inside, then taped over the sliced rubber, this is not ideal, but once again, I will be buying a bigger replacement grommet or something similar to use to replace this when I can.
Step 6 - Sit in the driver side rear seat, and look behind you, you will see 'AIRBAG' on a badge behind the rear headrest to the rear driver side of the car, unclip this gently with a trim tool, and it will expose a screw, unscrew that, and gently pull away at the trim, it will lever enough of a gap for you to feed the aerial wire from the boot into the car, from then, start pulling the wire through gently until all you need is through, then replace the trim, tighten the screw behind the AIRBAG badge, then put the badge back.
At this point, you are left with a lot of aerial cable dangling from the roof :)
Step 7 - Simply pull away gently at the headlining, and route the cable towards the A-Pillar on the drivers side of the car, use the outside of it to route (just under the rubber seal) so that it does not go near the airbags, there is enough of a gap for the cable to sink inside it and sit snug.
Once you get to the A-Pillar, again, route it down the outside, no need to remove the A-Pillar, head toward the fusebox area, pull off the fuse box door, and route the cable inside there (if you ever fitted a Bluetooth mic, you will be familiar with this part).
There is a storage box/drawer underneath the driver steering wheel, pull the handle so it opens, then squeeze the inside parts gently and pull it down so it comes down a little further, then simply pull it towards you, and that drawer will come out fully.
From there, nice and easy, feed the cable through towards the stereo.
Step 8 - Remove the Radio - this is nice and quick, simply pry the trim around the stereo with a trim tool and pull it off gently, exposing 4 screws that hold the Radio in place, unscrew those, and then pull the radio out towards you, I didn't bother undoing any of the cables, as I am lazy like that, so just put a cloth or piece of bubble wrap on the gearknob, and let the radio rest on that.
Use your right hand to feed the wire from underneath the steering area and your left hand put inside the gap where the radio was, and you should be able to make your hands meet :) pull the cable through including all excess cable, as you don't want that sagging anywhere, wind the excess cable gently and use some electrical tape or clips to keep the wire together.
Step 9 - Remember you took the FAKRA connector off this cable to help route it through the car? Well go back and get it as you need it now! Simply push the cable end into the FAKRA connector and replace the purple clip, nice and snug, then plug it into your DAB socket on your radio.
Slide the radio back gently, making sure you do not trap any wires, tighten the screws to keep the radio in place, and then put the fascia back.
Step 10 - Turn on your radio, press to get into the DAB screen, and then click 'SCAN'
Enjoy the delights of DAB radio! :)
Once again, I know this would have been better with pics, but I hope this helps anyone who wants to do this retrofit, it's honestly not a daunting task, and took me around 45 minutes to do.
« Last Edit: 22 January 2014, 16:06 by SeanyK »
Offline Obbzi
Re: DAB Antenna - OEM Parts - No Aerial On Show! - Done!
« Reply #1 on: 24 January 2014, 21:40 »
Excellent write up just needs pics!  :smiley:
2008 R32 DBP gone. 2008 GT TDI going 2009 GTI coming soon!
Offline th3_f15t
« Reply #2 on: 14 February 2014, 16:19 »
Would this be similar/identical on the mk5 Golf too?
The part you linked to on eBay is the same part I'm looking at for my own mk5 Golf! Which leads me to think that when people say the mk6 is just a prettier mk5, they aren't lying!
Moving over to Flickr, sorry for the broken picture links!
Offline DaveyGTD
« Reply #3 on: 15 February 2014, 02:32 »
I should have done pics, i'll see if when the weather gets better if I can do a rough guide using existing images.
Mike > I think so, I believe the MK5 is the same, the seller I linked to has a MK5 R32 and fitted one to his, so you could ask him, he is a helpful guy.
Offline th3_f15t
« Reply #4 on: 15 February 2014, 17:30 »
In talks with him now, seems proper helpful! Just trying to work out how a Kenwood DNX512BAD hooks up to the DAB/FM aerial...
Offline th3_f15t
« Reply #5 on: 16 February 2014, 09:02 »
F**K!!! I've just realised (thanks to that seller on eBay) that the guy who sold me a "DNX512DAB" actually sold me a DNX520VBT!!! No digital radio for me then!
How much of an idiot am I??? :rolleyes:
Offline Obbzi
« Reply #6 on: 17 February 2014, 21:40 »
If he has advertised it wrong, get a refund
Offline Tomv
« Reply #7 on: 16 April 2015, 22:38 »
Excellent write up. Massive help fitting an Rns315 DAB to my mk6 golf. As the article says The kufatec DAB antenna is indeed a direct replacement for the existing am/fm left hand antenna in the boot lid of the mk6 golf.
The tricky part is getting the tailgate trim off and back on again. Running the cable is easy. Use vasoline to slip it through the grommet (fold the cable end over, push it as far as poss then slide the  greased up grommet over and pull the looped cable through).
I connected the existing am/fm cable to port 2 of the new DAB antenna, leaving the new DAB cable in port 1. Excellent FM and DAB reception  :smiley:
Offline VeeDub
« Reply #8 on: 20 April 2015, 22:31 »
Excellent write up, I have just done this using the antenna module and cable from Kufatec, and I am no expert so you know it is easy to do if you follow the instructions  :grin:
Tomv, great tip to loop the cable and use Vaseline to feed it through the boot lid rubber grommet. So glad I had to put the job off a week as I ended up fitting the antenna the day after you posted your comment  :smiley:
Offline jimidee
« Reply #9 on: 14 May 2015, 14:21 »
Hi all,
Just looking for some advice if anyone can help.
I am looking at buying a RCD 310 (DAB) for my MK6 Golf Estate, and adapting the aerial with the Kufatec adapter as above.
Are the above instructions still valid for the estate and if so, is this really a job I could do myself or would it pay to get some to do the installation.
Thanks for your time
