Author Topic: Timing Chain tensioner Failure List (timing issue)- Please Update with Your Info  (Read 274417 times)
Offline Snoopy
  • Moderator
  • 30 years of GTI ownership.
If its really what you wanted go for it.
A mate of mine has terminal cancer. He always wanted an R32 mk5. So he got one late last year.
Not the best one in my eyes, but if hes happy.  :cool:
Current VWs = Mk6 GTI,  Mk1 GTI,  Mk1 Leon.
I should have bought a CSS in 2016.
Offline Jason123
Seen a January 2014 63 plate have this tensioner issue seems to have gone on longer this issue 😖
Offline Snoopy
  • Moderator
Depends what the route of the cause was determined. It could be a number of things. It could be as you say have failed as probability of any part failing is never zero.
It could be something else causing it to fail, oil feed, chain stretch, cambridge, sprocket ware, etc etc thenlist goes on.
Remember the mk7-8 still use a similar setup to the 6 just the ecu monitor the chain stretch and timing unlike the 6 and stop it destroying the engine.
