Author Topic: Timing Chain tensioner Failure List (timing issue)- Please Update with Your Info  (Read 269393 times)
Offline whiter_than_white
  • Seize the day or die regretting the time you lost!
Ok, having tried to start my 59 plate gti on Tuesday morning to no avail, I have just confirmed that there is no compression 😭
I am guessing chain tensioner as they are so common and had no issues with car up until this point.
As a mechanic and capable of stripping and rebuilding the engine I was wondering if anyone has done this? Is it possible or is it scrap? I ask because reading thru this post, all the warranty ones were new engine, no rebuild?? Thanks
Offline Snoopy
  • Moderator
  • 30 years of GTI ownership.
It all depends what has happened and bent / damaged. It may only need valve and head work but may need more. Pulling the head would be imo the first task to investigate.
« Last Edit: 03 February 2019, 17:44 by Snoopy »
Current VWs = Mk6 GTI,  Mk1 GTI,  Mk1 Leon.
I should have bought a CSS in 2016.
Offline joe6
I agree with snoopy. Head off first. It was cheaper to replace engines under warranty than mess about with rebuilds. From what I have read most of those with damage have got away with valve and head work. There are some videos on U-tube about engine rebuilds etc.
https://www.bing.com/videos/search?q=golf+mk6+GTI+engine+rebuild&view=detail&mid=4530712C190B7A75D4DF4530712C190B7A75D4DF&FORM=VIRE
Carbon Grey, 2010 a few VCDS mods. White 2016 Polo GTI (roller skate on steroids!!)
Having watched a few videos and a bit of my own knowledge I am going to pull the head over the weekend. I have already decided that if it's coming off it's having 16 new valves. I've priced chain parts thru tos with a new chain cover, going to get gaskets etc thru a local factors to try and cut some costs.
Just a couple of questions for those who have done them, there are 3 chains but nobody replaces oil pump chain? Does it need doing or is there no stress like the other 2?
Whilst head is off is there anything worth doing? Modification wise??
Offline drokkeh
HI All
Only just found out about this timing chain issue.  Put a deposit down on a Mk6 GTI 61 plate (50k mileage) yesterday.  Registered October 2011.
Not sure if the Timing chain/tensioner etc has ever been changed, havent looked at the service history yet.
Any advice on whether this age Mk6 might be ok etc etc?  Seeing conflicting reports as the when VW changed/revised this?
In simple terms if it has the latest/last version of the timing chain then its not likely to fail like the original?
Could negotiate the price down further to account for this work to be done if not.
Coming from a M4 Gti but this issue on the Mk6 looks catastrophic if not dealt with sensibly.
Thanks
Offline SRGTD
HI All
Thanks
Hi drokkeh,
Post #4 (at the bottom) gives details of the dates that the revised tensioners were introduced. If the car you’re getting hasn’t had the tensioner changed, then it won’t have the latest version (May 2012).
Gone but not forgotten;
2016 Polo GTI; Blue Silk
Offline drokkeh
Hi drokkeh,
Hi.  Ok.  Thanks for this.  So in simple terms if you have the May 2012 part (3rd and last revision) all is good?  Regardless whether it is factory fitted or retro fitted by dealer/VW specialist.
This is all I need to know really.
I know its hard to say 'yes, if you have the latest revision, the issue will NOT happen'  - But its much less likely i guess?
Just want to put my mind at rest for the sake of £300 - £400 replacement early on.
« Last Edit: 06 February 2019, 10:31 by drokkeh »
Offline joe6
Not sure what your mileage is? If over 75k then worth checking the timing chain and guides if replacing the tensioner as labour costs not much more, mainly parts costs. See #608 in this thread for method of checking timing chain stretch - uses VCDS and measuring block 93 and potential costs for doing the lot.
Offline drokkeh
Thanks.  The car I am buying is a 61 plate.  Mileage 50k.
Offline DanielPT
I am also onto this.. Looking to buy a Mk6 GTi, seen a couple of units and kinda falling for a 04/2010 one.
Now.. if i buy it and replace the chain/guide/tensioner, the chance of faillure disappears? Is it just change the parts and pedal to the metal?
