Author Topic: Timing Chain tensioner Failure List (timing issue)- Please Update with Your Info  (Read 269328 times)
Offline TomS_
bet yours sound like mine every time you start up your dirty diesel  :grin: :grin: :grin:
I think it sounds like a purring kitten.  :grin:
Mk6 GTD, MY12, candy white
Offline Snoopy
  • Moderator
  • 30 years of GTI ownership.
A couple of interesting links
hi there mate you might want to add this to the sticky list in the mk6 section as it will help a few owners an wont just disappear  :smiley:
http://www.vw.com/en/owners/parts-and-accessories/protection/recalls-campaigns.html
Current VWs = Mk6 GTI,  Mk1 GTI,  Mk1 Leon.
I should have bought a CSS in 2016.
Offline RocketRossUK
  • Moderator
dont have my VIN to han, have you entered yours in, anything come back?
Offline Snoopy
  • Moderator
Offline Tainton
I'm into 9 months of ownership with no problems so far.  Checked logbook and my vehicle was registered 31/03/10 and have just reached 36k, should I be concerned/worried over these failures? would mine have a revised version fitted as standard?
Mine does sound a little diesel like on start-up but no where near as bad as Ross video.
Purchased from local Nissan Dealer who also has VW franchise but it only came with a 3 month warranty with Nissan.
I'm assuming any failure would not be covered by VW?
Anyone folks recommend any specialist near Grantham (in between Notts and Lincoln).  Cheers Ash
Offline Jimmgc51
I bought private, no warranty but deal agreed.
It's the start up noise, as said before if it sounds rough for first 3 secs on cold start it may be on its way out!
Golf GTI 09, CW, Bi-Xenon, DCC, 18" Monza's, Jakarta, RNS510, Dynaudio, F&R parking sensors, Winter pack...
Ibiza Deep House mix for DL - https://soundcloud.com/jimmgc51/getting-deep-with-house
Offline mike.
I think that one only works for US cars, THIS is the UK one but mine comes back with no recalls.
Mk6 GTI 3dr | DSG | Tornado Red | 18" Monza 2 | LED Xenons | RNS510 | Bluetooth | Smoked LED tails | Cruise | Reversing Camera | TPMS | - now sold :(
Offline Snoopy
  • Moderator
Found this on the skoda forum.
Skoda TPI. Technical product information
Below is an extract from the ELSA electronic documentation.
 There is a lot more for this fault, but at least the issue number is on there:- 2024485/5.
This should give the technicians an idea where to look....Technical product information Transaction No.: 2024485/5
Damage of timing chain tensioner
Release date: 27-Jun-2011
Customer statement / workshop findings
Engine cannot be started, the Check warning lamp is on
In the engine CU, the following fault is stored:• 00022 P0016 CMP Sensor -G40 Engine Speed (RPM) Sensor -G28 Incorrect allocation;• 00808 P0328 Knock Sensor 1-G61 Circuit High.
Technical background
Because of the defective function of the timing chain tensioner, the timing chain may get too loose during the start causing a valve timing change.
 This may result in a contact of valves with pistons.
Production change
Reinforced timing chain tensioner – new part 06H 109 467 T.
It was introduced to series production in CW 20, 2010.
Measure Check, repair
1:. VAS check, Guided Fault Search.
2. Remove the lower cover of the timing chain (see Elsa); check the timing chain tensioner function by pressing on the tensioning rail of the timing chain (Fig.1) against the tensioner. If the piston is inserted into the tensioner’s body (see Fig.2), the ratchet of the tensioner’s piston or the tensioner’s latch has been damaged. If you do not find a damaged timing chain tensioner even after a repeated check (see Fig.3), continue with point No. 6
3.. If a damaged timing chain tensioner was found, continue with examining pistons and valves (removing cylinder head or using of endoscope).
4. If pistons and valves are not damaged, replace the timing chain tensioner with the part 06H 109 467 T and carry out a new setting of the timing gear.
5. If pistons and valves are damaged, replace the engine.
6. Prior to a new timing chain setting, check the possible seizing of the camshafts. Repair by replacing the damaged parts
7.. If only the timing chain setting is shifted without the above parts being damaged, the fault was caused by exceeding the maximum engine revolutions (see the printout of the fault memory of the engine CU). In this case, a warranty repair is not possible
« Last Edit: 03 January 2014, 23:43 by Snoopy »
Offline Obbzi
This is how mine sounds now with a brand new engine
http://www.youtube.com/watch?v=75joqSILfLs&feature=youtu.be
2008 R32 DBP gone. 2008 GT TDI going 2009 GTI coming soon!
Offline Snoopy
  • Moderator
Quote from: Snoopy link=topic=246903.msg2417416#msg2417416
http://youtu.be/DQ_MwM1nQZ4
Dont know if mines just a noisy injector or something else as it seems to be mostly from the centre area of the engine. :undecided: also doesnt quite down as if oil pressure rises. :undecided:
« Last Edit: 03 January 2014, 18:53 by Snoopy »
