Author Topic: GTD Fuel Tank Capacity?  (Read 20726 times)
Offline Mark V GTD
Re: GTD Fuel Tank Capacity?
« Reply #30 on: 19 November 2017, 15:49 »
How is that possible when the tank is 50 litres capacity?
Offline fredgroves
« Reply #31 on: 20 November 2017, 09:42 »
Because the filler pipe will hold another 2l?
Offline itavaltalainen
« Reply #32 on: 21 November 2017, 19:03 »
It has a nominal capacity of 50l, plus expansion tank plus filler neck. You could probably get 55 liters in there if you have enough patience and you're going to empty it fast again.
09/2016 Golf VII GTD DSG 50k miles
Gone: 11/2013 Golf VII Variant GT 2.0 TDI pacific blue - 123k miles
DASH SWAPS and KEYS LEARNING for most VWs up to MY2005 even if you don't have the PIN - FAULT CODES - ADAPTATIONS -  Windows via remote fob for Golf 4 and other 2000s VAGs -OXON and the whole country
Offline Daz Auto
  • Other brands of washing powder are available.
« Reply #33 on: 20 December 2017, 13:42 »
From my experience of driving VAG cars they have a fuel reserve. In my last 2 diesel Golfs I would get a warning 50 miles remaining. However, IIRC the fuel reserve was 8L and both cars did roughly 10 miles for every litre = 80miles on reserve. On several occasions I tested this theory and drove an extra 30miles after the car said 0 miles remaining. Though one time I did manage to put 57litres into my old 55L tank :shocked:
I have never managed to put 50L into our A3 even when it said 0 miles remaining. The manual says it has a 7L reserve and the warning comes on at 50 miles remaining. It also does around 10 miles to a litre. So it should do another 20 miles past 0 miles remaining.
When you first get a warning on the Mk7 GTD does it say 35 miles remaining (like my GTI) or 50 miles remaining (like my previous MK6 GTD)?
I have twice managed to put nearly 53L into my GTI PP. The car had just said 0 miles remaining. :shocked: So either I have no extra fuel reserve past 0 and was running on fumes with a 50L tank. Or my car has a 55L tank the same as the Golf R has.
I would just have to drive 10 miles after the car said 0 remaining. Unfortunately, it is bad to allow a modern engine run out of fuel. So I'm not going to risk it with this car.
« Last Edit: 20 December 2017, 13:50 by Daz Auto »
10/8/2017 - GTI Performance, Red,5dr DSG, Art Velour, Keyless, Dynaudio, DCC, Lane & DLA , rear cam, Tow Bar.
Previous- Mk6 GTD, Mk5 Golf Match
Offline JasonGTD
« Reply #34 on: 12 August 2018, 15:14 »
I'm off on a road trip tomorrow so just topped up the tank, had 115 miles left in it, cost 50 quid to fill it, and now it shows that I have 390 miles of range WTF.
2018 MK 7.5 GTD 3 Dr in Pure White,Extras,Front Splitter, Carbon Exhaust Tips.
Offline mcmaddy
« Reply #35 on: 12 August 2018, 15:28 »
Did you reset everything?
Gti PP, Tungsten, Tech & Parking packs, HBA
Offline JasonGTD
« Reply #36 on: 12 August 2018, 15:32 »
No, but the range resets itself when you fuel up.
Offline rjwojcik
« Reply #37 on: 12 August 2018, 15:38 »
Mine normally shows just over 500 after I fill it to the brim.  My real life MPG is 48.
Current: 2016 Mk7 GTD with a "lot" of toys
Gone: 2014 Mk7 TDI GT
Gone: 2016 F80 M3 with a few mods
Gone: 2009 E82 135i with some mods
Cancelled order: Mk6 Golf GTI 5dr DSG, Monza Shadows, Carbon Grey, leather, sunroof, cruise, DAB, parking sensors, RCD510 and Dynaudio, bluetooth, Lux pack, Winter pack, fixed price service plan.  Ordered 16-Aug, originally BW48, then BW01, then no BW, then BW10, now BW09 <<< Cancelled 15-Dec >>>
Offline JasonGTD
« Reply #38 on: 12 August 2018, 15:40 »
That's what I was expecting.
Offline mcmaddy
« Reply #39 on: 12 August 2018, 16:08 »
The range looks at your current mpg so if you've been hooning around before filling up and it says 15mpg that's what it'll work your miles to refill on. Try resetting your current readouts and check what the predicted miles is then.
