Author Topic: dai-cymru - 1989 GTI 16V 1 owner  (Read 24508 times)
Offline dai-cymru
  • 1989 MK2 16V
Re: dai-cymru - 1989 GTI 16V 1 owner
« Reply #10 on: 05 January 2014, 11:32 »
after about 6 hours of cutting/grinding over a 3 day period. Finally parted the head from the block. 10 years of sitting in a barn deffo makes for seized EVERYTHING!!  Next job is to strip head down but going to be a drama as every bolt holding the inlet manifold on is seized & starting to round off. Will get the head reconditioned then will take the block out and put some new rings and bearing shells in,  Will try get some photos up later. Wish I had a nice warm garage to work in!!
Offline dai-cymru
  • 1989 MK2 16V
« Reply #11 on: 08 January 2014, 14:24 »
Pretty sure there should be some more parts on the car than this  :grin:
Offline dai-cymru
  • 1989 MK2 16V
« Reply #12 on: 11 January 2014, 08:33 »
Is it supposed to look like this?
Offline dai-cymru
  • 1989 MK2 16V
« Reply #13 on: 06 February 2014, 22:21 »
Offline dai-cymru
  • 1989 MK2 16V
« Reply #14 on: 06 February 2014, 22:25 »
Current condition of my engine  have spent ages stripping and cleaning  block now ready for paint then put it all back together  picked up head today .  Would appear had 8 valve guides stuffed but all been sorted now. Bores look good so going to hone them and refit piston and crank with new shells and rings
Offline dai-cymru
  • 1989 MK2 16V
« Reply #15 on: 27 April 2014, 21:14 »
Sorry guys been a while since I updated. A fair bit has been done. Engine is nearly rebuilt and ready to go back in. Head & cams & Timing belt and water pump on. Just got to got clutch and flywheel and gearbox and will throw it back in the car. At my current rate of chance to work on it that will prob be months.
« Last Edit: 27 April 2014, 21:17 by dai-cymru »
Offline dai-cymru
  • 1989 MK2 16V
« Reply #16 on: 07 July 2014, 15:19 »
Quick update, cars come along nicely but having a few running issues  think it's dragging in air from inlet manifold so need to pop it back off and look what's going on
Offline dai-cymru
  • 1989 MK2 16V
« Reply #17 on: 07 July 2014, 15:20 »
Offline dai-cymru
  • 1989 MK2 16V
« Reply #18 on: 01 April 2015, 15:27 »
Righto. Well been quite some time since I posted. Work and family commitments plus shocking weather have made for slow progress. However I have now replaced the rotten rear panel. That was fun. Not. Also I have replaced the complete dizzy and new bosch injectors for £200!! Also traced a fault fo the metering head. Waiting a rebuild kit from America at the moment to hopefully cute it. Here's some progress pictures
« Last Edit: 05 April 2015, 09:29 by dai-cymru »
Offline dai-cymru
  • 1989 MK2 16V
« Reply #19 on: 05 April 2015, 09:31 »
