Author Topic: mk4 golf fuse list.  (Read 14839 times)
Offline mcgee9t2
mk4 golf fuse list.
« on: 04 November 2013, 19:29 »
mods. please move / delete as you see fit. not sure if theres already one of these lists on here but usefull if not.
MKIV FUSE LIST
1. Washer nozzle heaters, glove compartment light, memory seat control module (10A).
2. Turn signal lights (10A).
3. Fog light relay, instrument panel light dimmer switch (5A).
4. License plate light (5A).
5. Comfort system, cruise control, Climatronic, A/C, heated seat control modules, automatic day/night interior mirror, control module for multi-function steering wheel, control unit in steering wheel (7.5A).
6. Central locking system (5A).
7. Back-up lights, speedometer vehicle speed sensor (VSS) (10A).
8. Open
9. Anti-lock brake system (ABS) (5A).
10. Engine control module (ECM): gasoline engine (10A); diesel engine, Model Year 2000 > (5A).
11. Instrument cluster, shift lock solenoid (5A).
12. Data Link Connector (DLC) power supply (7.5A).
13. Brake tail lights (10A).
14. Interior lights, central locking system (10A).
15. Instrument cluster, transmission control module (TCM) (5A).
16. A/C clutch, after-run coolant pump (10A).
17. Open.
18. Headlight high beam, right (10A).
19. Headlight high beam, left (10A).
20. Headlight low beam, right (15A).
21. Headlight low beam, left (15A).
22. Parking lights right, side marker right (5A).
23. Parking lights left, side marker left (5A).
24. Windshield and rear window washer pump, windshield wiper motor (20A).
25. Fresh air blower, Climatronic, A/C (25A).
26. Rear window defogger (25A).
27. Motor for rear windshield wiper (15A).
28. Fuel pump (FP) (15A).
29. Engine control module (ECM) gasoline engine (15A); diesel engine (10A).
30. Power sunroof control module (20A).
31. Transmission control module (TCM) (20A).
32. Injectors: gasoline engine (10A); diesel engine (15A).
33. Headlight washer system (20A).
34. Engine control elements (10A).
35. 12 V power outlet (in luggage compartment) (30A).
36. Fog lights (15A).
37. Terminal (86S) on radio, Instrument cluster (10A).
38. Central locking system (with power windows), luggage compartment light, remote/fuel tank door, motor to unlock rear lid (15A).
39. Emergency flashers (15A).
40. Dual tone horn (20A).
41. Cigarette lighter (15A).
42. Radio (25A).
43. Engine control elements (10A).
44. Heated seats (15A).
Fuse arangements in fuse bracket/battery:
S162. Glow plugs (coolant) (50A).
S163. Fuel pump (FP) relay/glow plug relay (50A).
S164. Coolant fan control (FC) control module/coolant fan (40A).
S176. Relays panel interior (110A).
S177. Generator (GEN) (90 Amp.) (110A).
Generator (GEN) (120 Amp.) (150A).
S178. ABS (hydraulic pump) (30A).
S179. ABS (30A).
S180. Coolant fan (30A).
fuse bracket/battery arrangement
fuse box located in dash on drivers side iirc behind a removable panel / door on the side
« Last Edit: 04 November 2013, 19:31 by mcgee9t2 »
Offline mcgee9t2
Re: mk4 golf fuse list.
« Reply #1 on: 04 November 2013, 19:32 »
Anyone got any info or know if any of them are wrong please pm me and I will correct it in the original post (so we don't have original post information wrong and correct info located on a different page)
all information taken from http://forums.vwvortex.com/showthread.php?951306 so if its wrong blame the guys over on vortex
Offline dom
  • Back in a Mk4
« Reply #2 on: 04 November 2013, 19:38 »
Already loads of fuse info here:
http://www.golfgtiforum.co.uk/index.php?topic=87372.0
Good find anyway.
Offline mcgee9t2
« Reply #3 on: 04 November 2013, 19:40 »
thought id seen some somewhere before.
ah well, mods delete/merge into the original thread as you see fit.
