Not posted in this thread for a while, so thought I'd just update it with a minor "tweak" I learned the other day. Not an essential mod by any means but I quite like it.
As you know, when you change driver profiles modes, all the information comes up on the main infotainment screen (including a little text area in the top left corner indicating the currently selected driver profile).
Well with this very simple mod, not only does it display on this but also in the DIS screen when you have finished selecting, but upon starting of the car, it flashes up for just a second or so to remind you of the currently selected profile. One slight amusement is that all my modes appear the same as in the infotainment screen (Comfort, Normal, Sport, & Eco) except one - Individual mode comes up in the DIS as "RACE Mode" vrooom vrooom..........
Any the mod is simply to go into the CAN gateway controller [19] and enable the check mark on Byte [8] Bit [4]
That's it, and you should be let with the following:
Hi,
I have a problem with the ACC.
I made this modification in the controller 19 and the enable bit 4 in byte 8 ACC stopped working.
Deactivated Bit 4 and even then the ACC continues disabled.
In autoscan shows no failure.
To start the car the MFD says "ACC Disabled"
the button on the steering wheel that triggers the ACC also does not work.
By pressing the MFD button says "ACC Disabled" "
The MODE button also does not work.
Can anyone help me how to solve this problem?
This is my autoscan:
Regards,
Code:
VIN: WVWHE6AU9EW405917 License Plate:
Chassis Type: AU (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 55 5F A5 A9
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
A9-Struct. Borne Sound -- Status: OK 0000
Address 01: Engine (J623-CHHB) Labels: 06K-907-425-V1.clb
Part No SW: 5G0 906 259 HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0007
Revision: --H13---
Coding: 091D00322464050B3000
Shop #: WSC 01357 011 00200
ASAM Dataset: EV_ECM20TFS0215G0906259 001011
ROD: EV_ECM20TFS0215G0906259_SK37.rod
VCID: EBD0C28902182346DE5-80BE
No fault code found.
Readiness: 1110 0001
Address 02: Auto Trans (J743) Labels: 0D9-927-770.clb
Part No SW: 0D9 300 040 S HW: 02E 927 770 AQ
Component: DQ250-6F MQB H52 4313
Revision: 03252204 Serial number: TFK01404130376
Coding: 0014
ASAM Dataset: EV_TCMDQ250021 001001
ROD: EV_TCMDQ250021_AU37.rod
VCID: 27587EB95E704726FAD-8072
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379.clb
Part No SW: 5Q0 907 379 AB HW: 5Q0 907 379 H
Component: ESC H31 0557
Revision: 00000000 Serial number: 6100400000048C
Coding: 01FA6BA13420297103800601C1CAA980D62C94C0608395F7F842503AC209
ASAM Dataset: EV_Brake1UDSContiMK100IPB 033001
ROD: EV_Brake1UDSContiMK100IPB_VW37.rod
VCID: 7CF271D5F77634FEC7F-8029
Address 05: Acc/Start Auth. (J518) Labels: None
Part No SW: 5Q0 959 435 A HW: 5Q0 959 435
Component: VWKESSYMQB 021 0604
Revision: 00021000 Serial number: 0333057692
Coding: 030C0C
ASAM Dataset: EV_KessyHellaMQBAB 002011
ROD: EV_KessyHellaMQBAB_AU37.rod
VCID: 3A7EB7CDBDC2CACE953-806F
Address 08: Auto HVAC (J255) Labels: 5G0-907-044.clb
Part No SW: 5G0 907 044 AA HW: 5G0 907 044 AA
Component: Climatronic H02 0805
Revision: 00001K06
Coding: 00020014200100011105000000101000
ASAM Dataset: EV_ACClimaBHBVW37X 003018
ROD: EV_ACClimaBHBVW37X_SE37.rod
VCID: 66C633BD99FA9E2E01B-8033
Fresh Air Blower Front:
Refrigerant Pressure And Temperature Sender:
Air quality sensor:
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 5Q0 937 084 AE HW: 5Q0 937 084 AE
Component: BCM MQBAB H H16 0124
Serial number: 00011411401115
Coding: 00111E46C24122FB0BA44080B10C07281800000000000000000000000000
ASAM Dataset: EV_BCMCONTI 012001
ROD: EV_BCMBOSCH_SE37.rod
VCID: 7BF072C9F27833C6CE5-802E
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A
Component: WWS 140412 042 0551
Serial number: 140416154737
Coding: 0E4DDD
Subsystem 2 - Part No SW: 5Q0 955 547 HW: 5Q0 955 547 Labels: 5Q0-955-547.CLB
Component: RLFS 024 0042
Serial number: Y14M04D28H04M05S55S7
Coding: 00A8DD
Subsystem 3 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY140914E0A
Subsystem 4 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000059331555
Subsystem 5 - Part No SW: 8V3 959 591 HW: 8V3 959 591
Component: J245 PS73.014 H02 0007
Serial number: WOO28704599
Coding: 181901
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-298.clb
Part No SW: 5Q0 919 298 D HW: 5Q0 919 298
Component: PARKHILFE PLA H11 0042
Revision: -------- Serial number: 61131410902114
Coding: 0031161051
ASAM Dataset: EV_EPHVA2CAU3700000 003019
ROD: EV_EPHVA2CAU3700000_VW37.rod
VCID: 408AC525DB1E901EDB7-8015
Address 13: Auto Dist. Reg (J428) Labels: None
Part No SW: 5Q0 907 572 B HW: 5Q0 907 572 B
Component: ACC Bosch MQB H04 0200
Serial number: 26041477030356
Coding: 001C1700FE0339
ASAM Dataset: EV_ACCMRRBoschVW372 001014
ROD: EV_ACCMRRBoschVW372_AU37.rod
VCID: 3666A3FD89DA2EAE71B-8063
Address 15: Airbags (J234) Labels: 5Q0-959-655.clb
Part No SW: 5Q0 959 655 AA HW: 5Q0 959 655 AA
Component: AirbagVW20 014 0386
Serial number: 003MLR059KJ/
Coding: 98CCC000000000005C0000CF004800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002130
ROD: EV_AirbaVW20SMEVW37X_VW37.rod
VCID: 7F0886D9E6602FE6E2D-802A
Seat belt tensioner; left:
Subsystem 1 - Part No SW: 5G0 980 945 B HW: 5G0 980 945 B
Component: BeltPretRevFL H35 0341
Serial number: 34169667B25041440966
Coding: 333135
Seat belt tensioner; right:
Subsystem 2 - Part No SW: 5G0 980 946 B HW: 5G0 980 946 B
Component: BeltPretRevFR H35 0341
Serial number: 34169668B29041470313
Coding: 333135
Crash sensor for side airbag; driver side:
Subsystem 3 - Part No SW: ----------- HW: 480 000 504 14
Component: SideSensor_Df 001 0887
Serial number: 35767000000465BC9F04
Coding: 2D2D2D
Crash sensor for side airbag; passenger side:
Subsystem 4 - Part No SW: ----------- HW: 480 000 504 14
Component: SideSensor_Pf 001 0887
Serial number: 35867000000737BC9F07
Coding: 2D2D2D
Crash sensor for side airbag; rear driver side:
Subsystem 5 - Part No SW: ----------- HW: 480 401 004 14
Component: SideSensor_Dr 001 6149
Serial number: 3516502C31529DF3B14F
Coding: 2D2D2D
Crash sensor for side airbag; rear passenger side:
Subsystem 6 - Part No SW: ----------- HW: 480 401 004 14
Component: SideSensor_Pr 001 6149
Serial number: 3526502991529DF4015A
Coding: 2D2D2D
Crash sensor for front airbag; driver side:
Subsystem 7 - Part No SW: ----------- HW: 480 401 604 14
Component: FrontSensor_D 001 6149
Serial number: 3556502C1157E9D2B3FX
Coding: 2D2D2D
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 507 EC HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 19041404221923
Coding: 0C10
ASAM Dataset: EV_SMLSKLOMQB 017001
ROD: EV_SMLSKLOMQB_AU37.rod
Address 17: Instruments (J285) Labels: 5G0-920-XXX-17.clb
Part No SW: 5G6 920 870 HW: 5G6 920 870
Component: KOMBI 314 2210
Coding: 07AD09182F90000800886A01040000
ASAM Dataset: EV_DashBoardVDDMQBAB 008031
ROD: EV_DashBoardVDDMQBAB_AU37.rod
VCID: ECD2C1950716247ED7F-80B9
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 5Q0 907 530 Q HW: 5Q0 907 530 F
Component: GW MQB High 125 1164
Revision: -------- Serial number: 0001889636
Coding: 030100042B085900EF00027E1C0F00010001000000000000000000000000
ASAM Dataset: EV_GatewLear 010015
ROD: EV_GatewLear_AU37.rod
VCID: 3F88C6D9A6E0EFE6A2D-806A
Alternator:
Multifunction unit control module:
Subsystem 2 - Part No SW: 5G0 959 442 N HW: 5G0 959 442 N
Component: E221__MFL-DC1 H06 0038
Serial number: 29140000512690024152
Coding: 2DFFFF
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 5Q0 915 181 E HW: 5Q0 915 181 E
Component: J367-BDMHella H03 8043
Serial number: 4844303203
Address 2B: Steer. Col. Lock (J764) Labels: 5Q0-905-861.clb
Part No SW: 5Q0 905 861 A HW: 5Q0 905 861 A
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 14000103771005
Coding: DD00000000000000
ASAM Dataset: EV_ELVMarquMQB 004111
ROD: EV_ELVMarquMQB.rod
VCID: 346299F59FA63CBE4FF-8061
Address 42: Door Elect, Driver (J386) Labels: None
Part No SW: 5Q0 959 593 B HW: 5Q0 959 593 B
Component: TSG FS 020 0025
Serial number: 19041404080300
Coding: 003F1220D000048000000000
ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
ROD: EV_DCUDriveSideEWMAXKLO.rod
Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A
Component: FOND_FHSG_DRV 005 0005
Serial number: 00000000000002498641
Coding: 010000
Address 44: Steering Assist (J500) Labels: None
Part No SW: 3Q0 909 144 F HW: 3Q0 909 144 F
Component: EPS_MQB_ZFLS 503 5043
Coding: 8303
ASAM Dataset: EV_SteerAssisMQB 010031
ROD: EV_SteerAssisMQB.rod
VCID: 3564A4F194DC25B6781-8060
Address 52: Door Elect, Pass. (J387) Labels: None
Part No SW: 5Q0 959 592 B HW: 5Q0 959 592 B
Component: TSG BFS 020 0025
Serial number: 20041406070170
Coding: 003F1220DE00048000800000
ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
ROD: EV_DCUPasseSideEWMAXKLO.rod
Subsystem 1 - Part No SW: 5Q0 959 812 A HW: 5Q0 959 812 A
Component: FOND_FHSG_PSG 005 0005
Serial number: 00000000000002480215
Coding: 190000
Address 55: Xenon Range (J745) Labels: 7P6-907-357.clb
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Revision: -------- Serial number: --------------
Coding: 029A01104F010200
ASAM Dataset: EV_HeadlRegulVWAFSMQB 001120
ROD: EV_HeadlRegulVWAFSMQB.rod
Subsystem 1 - Part No SW: 3D0 941 329 A HW: 3D0 941 329 A
Component: LeiMo links H05 0012
Coding: 900000
Subsystem 2 - Part No SW: 3D0 941 329 A HW: 3D0 941 329 A
Component: LeiMo rechts H05 0012
Coding: 900000
Address 5F: Information Electr. (J794) Labels: None
Part No SW: 5G0 035 045 B HW: 5G0 035 045
Component: MU-H-N-RW H42 0291
Serial number: A311A0E7503202
Coding: 027300030000000011220002001800001F0203F401000100D7
ASAM Dataset: EV_MUHig4CHBAS 001040
ROD: EV_MUHig4CHBAS.rod
VCID: 1F48665906208FE682D-804A
Media Player Position 1:
Subsystem 1 - Part No SW: 5G0 919 606 HW: 5G0 919 606
Component: ABT_High H51 0022
Serial number: VWZ8Z9PJ600WYG
Engine Control Module 2:
Subsystem 2 - Part No SW: V03 959 800 TJ HW: -----------
Component: ROW 2014 --- 0030
Serial number: --------------------
Door Electronics Rear Left:
Subsystem 3 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote --- 4005
Address A5: Frt Sens. Drv. Assist (R242) Labels: 5Q0-980-653.clb
Part No SW: 5Q0 980 653 F HW: 5Q0 980 653
Component: MQB_MFK H05 0052
Serial number: 10000069374
Coding: 0000020000020303000400000100000100
ASAM Dataset: EV_MFKBoschAU370 001001
ROD: EV_MFKBoschAU370_AU37.rod
VCID: 3B70B2C9B2F8F3C68E5-806E
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 5G0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0013
Serial number: 140329201771
ASAM Dataset: EV_SoundActuaGen2AU64X 003010
ROD: EV_SoundActuaGen2AU64X.rod
End ---------------------------------------------------------------------
